grinding noise???
Discussion in 'Modifications And Maintenance' started by carbonfiber, Apr 24, 2006.
  1. carbonfiber
    carbonfiber New Member
    my first gear sometimes grind when i try to put it in gear sometimes at a complete stop to a rolling start at about 3 to 5 mph seems to be getting worst, is it because i let my wife drive. and i do need a new clutch soon.
  2. AWDimprezaL
    your 1st gear sycros are shot...try some GM syncromesh tranny fluid, or somthing like it...
  3. John16V
    John16V Well-Known Member
    Hum...me too sometime, but only when it is cold out. Is that mean my first is shot too? How can you tell? And where can you this stuff at?? Do you have to drain your tranny fluid first?
  4. AWDimprezaL
    you can get it at any chev dealer, yes you hafta drain your fluid. there are many other kinds on the market, i just have had great luck with this stuff. i used to grind 1-3 every time...now it doesnt grind at all...40K miles later even!
  5. LVT
    LVT Well-Known Member
    yours can't be shot, you barely have enough miles to effect the tranny enough to kill the syncro let alone your car was store most of its life. I'd suggest just changing out the fluid. try uncle scotty's blend. i have it in my car and i love it! it consist of 1qt syncromesh(found at autozone), 2 qts castrol hyper C, and 1qt redline lightweight shock proof. you can drive mine to see how it feels if you'd like. i also have redline in my rear diff. its always better to do both at once.
  6. 02blubru
    I have this same problem, running amsoil in the tranny. Is this something that would be coverd under an extended warranty?
    It also chatters on take off sometimes when I first start driving it after it has sat for a day. the tranny was in nuteral while it sat.
  7. wrxpeed
    wrxpeed CobraPeed
    +1, its great stuff. I had the same problems before; i couldn't put my car into first unless I rev matched and was at a complete stop. After the Cocktail, can put into first at 20mph with no problems at all. Its great.
  8. carbonfiber
    Alot Of Good Answers Thanks,
  9. AWDimprezaL
    bill, you may want to swap in some sort of cocktail into yours as well, full synthetic is almost bad for slipping syncros, it just works too damned good!
  10. 02blubru
    You thinking some synchro mesh gear lube plus the amsoil?
