Group A parts
Discussion in 'Vendor Announcements/Sales/Discounts' started by Reason, Aug 16, 2007.
  1. Reason
    Reason New Member
    $120 + Shipping
    $230 (front and rear)+ Shipping
    Product Highlights:
    * 6061 Aluminum
    * Anodized
    * CNC milled
    * New zinc coated hardware supplied
    Benefits:
    * Reduces body roll
    * Improvement over stock plastic pieces
    * Improves turn-in
    * Helps with throttle-off over steer
    * Cool-looking
    I think I have these right
    Applications
    GA-013-A (FRONT) ~ 90-04 Legacy/ 94-07 Impreza/ 98-02 Forester
    GA-010-A (FRONT) ~ 05+ Legacy
    GA-012-A (REAR) ~ 90-99 Legacy/ 94-07 Impreza/ 98-02 Forester
    GA-011-A (REAR) ~ 00-07 Legacy
    GA-010-A
    Small I End Link
    GA-011-A
    Long I End Link
    GA-013-A
    Small I End Link (Style 2)
    Designed for the narrower front track vehicles such as wagons, GC8, etc.
    GA-012-A
    C End Link
    $100 + Shipping
    Product Highlights:
    * 6061 T6 Aluminum
    * Precision Milled
    * Kit includes:
    o Throttle body spacer
    o Throttle cable bracket *
    o Longer throttle body bolts
    o New gasket
    o Longer vacuum hose *
    Benefits:
    * Increases fuel economy
    * Dyno proven to increase torque by 2-4 WHP
    * Increases the torque curve in the lower RPM range
    * Looks damn cool!
    $85 + Shipping
    Product Highlights:
    * 6061 Aluminum
    * Anodized
    * CNC milled
    * Precision Turned Bushing Bores
    * Cast urethane bushings
    $28+ shipping
    Subframe Locking Kit
    Product Highlights:
    * Zinc Coated Hardware
    * Two piece design is easier to install and ensures longer reusability as the bolt portion can be replaced at will with a standard easily obtainable bolt.
    $90 + Shipping
    Lightweight Crank Pulley
    Product Highlights:
    * 100% made in Canada
    * 6061 Aluminum
    * Anodized
    * CNC milled
    * Balanced
    * Easy Install
    * 695 grams / 1.5 lbs
    * NOT under-driven
    * Uses stock belts for install
    $65 + Shipping
    Alternator Pulley
    Product Highlights:
    * 6061 Aluminum
    * Anodized
    * CNC milled
    * Balanced
    * Easy Install
    * NOT under-driven
    $75+ shipping
    Product Highlights:
    *6061 Aluminum
    *Anodized
    *CNC milled
    *Balanced
    *Easy Install
    *NOT under-driven
    *Uses stock belts for install
    Benefits:
    *Allows engine to rev higher
    *Improves gas economy
    *Helps for heel / toe technique
    PM for pricing
    Product Highlights:
    *6061 Aluminum
    *Anodized
    *CNC milled
    *Adjustable throw and height
    *Easy Install
    *Universal kit
    Benefits:
    *Shorter throws means faster shifting
  2. TSTRBOY2004
    nice products...
  3. Reason
    Reason New Member
    Yea they are, they have a few more cool things coming out in the next few months.
  4. Reason
    Reason New Member
    Is anyone interested in a group Buy? Depending what item it is I can combine it with other forums.
  5. Dynapar
    what is the fitment on the throttle body spacers?
    also is it possible to the the throttle cable relocator bracket seperate from the TB spacer?
  6. BBsRS
    BBsRS Well-Known Member
    I have their Throttle Body Spacer on my RS!! It definitly makes a difference. It gets rid of the scavaging for air around that certain rpm range for those who know what i'm talking about. bumped me +3hp and +4-+6ft/lbs to the wheels!!! As for gas milage improvment hmmmm i don't know because my car does 400+ miles on a full tank of gas anyways before and after installing it so it doesn't bother me ;).
  7. Reason
    Reason New Member
    The fitments are 2.5 SOHC drive by cable (this one will also work on the 2.h DOHC DBC)
    Theres another one for the 05+ drive by wire.
    Sorry for the late response, I never got an email notification.
  8. Reason
    Reason New Member
    Price drop on the pitch stop and subframe locking bolts!
    I also have an eBay store now
    My eBay store
  9. Reason
    Reason New Member
    New parts! check them out!
