Grrr.Electical Gremlins, please help me out.
Discussion in 'General Subaru Discussion' started by Beej, Sep 16, 2004.
  1. Beej
    Beej New Member
    OK, so my RS's turn signals and hazards don't work. I bought the car without the hazard switch, and I know they run on the parallel ciruit, so I had assumed upon installing the hazard switch, I would be free and clear.
    WRONG!! Still nothing.
    I can hear the relay click when I hit the hazards or signals, there are no blown fuses.
    Since the car did have a front end impact with a deer, I am betting there is something going on with the wiring up front.
    Any tips/tricks to removing the bodywork up front (Bumper/headlights) before I break something?
    Thanks fellas.
    Also, if anyone has a wiring diagram for this circuit, I will buy you lunch.
  2. BlackDubRX
    BlackDubRX New Member
    BE CAREFUL Dont' just go rpping off parts. Maybe you should just go buy a repair book, or borrow it from the library.
  3. Beej
    Beej New Member
    btw, this is a 2001 RS.
  4. igofast
    igofast New Member
    I think your hazard may be hooked up wrong. I had this problem before. If the hazard button is partially on, nothing else will work. Double check that first before moving on.
  5. Beej
    Beej New Member
    Partially on? It is fully snapped in. What do you mean?
  6. igofast
    igofast New Member
    I mean if the hazard button is partially pressed in(not fully engaged, but not fully disengaged) it will lock up all the turn signals and give the symptoms you describe.
  7. Beej
    Beej New Member
    found it! It was a relay.
