it takes a bit of practice to be good. i have been trying for awhile and i am only "ok" at it. the physics are pretty realistic so you can try some of the normal stuff, like let off or swedish flick. good luck
^^^no its not real at all. the ebrake dont lock up, u got the car to slide already, and then u push the gas, the car wont try to slide more at all even if u switch the lsd to a 2 way. and i think the steering angle is lower too. heres the set up of my sil80 power: about 230 suspension: spring rate, shock damper, set to hardest on the back. sway bar set to biggest on the back. -2degree camber in front, 0 in back. and a roll cage too. drive train: carbon drive shaft and a 2 way tires: cant remember brake:stock and i shut off those traction control stuffs also. and i still cant drift.
put the traction controll, oversteer, and understeer to level 1, or the trac off and the understeer/oversteer to 1
^^^ yah thats very important. with the driving aids on it makes it really hard to get any sideways movement.
http://www.gtplanet.net/forum/forumdisplay.php?f=141 This will answer all you questions and solve all your problems So will this page... http://www.gtplanet.net/forum/showthread.php?t=72878
lol. mike that is some pretty impressive ar you got going there. kelly how much camber do you have on that impreza???!!!???
