Hackers remotely start Subarus via texting
Discussion in 'Off-Topic' started by ofspunk7, Aug 8, 2011.
  1. ofspunk7
    Full Story Click Here
    Two security researchers at a Black Hat security conference demonstrated how they were able to break into a Subaru Outback using a technique they call "war texting" in just a few hours, a revelation sure to warrant a mention in the REI customer newsletter.
    The technique appears to apply to cars using a cell-based system for unlocking and remote start (like GM and Mercedes also use). The hackers established their own local GSM network and intercepted signals sent between the server/car to sniff out the passwords.
    It's probably a minor threat to cars as the work required seems too great considering you'll still probably need a key to get the car to drive. The bigger threat exists if the "war texting" procedure is used to hack into other similarly controlled systems like traffic signals. Also, because it sounds like something tweens would be really good at.
  2. Musashi
    I think it would become a much greater issue should they shut you and other down while in traffic.
  3. ofspunk7
    There was a group that was able to shut down the ECU on the road using an access point through the TPMS...
    LINK Defcon: Hacking Tire Pressure Monitors Remotely
    I read somewhere that a college group did this too (a while back) and was able to fry the ECU.
  4. ofspunk7
    Found it...
    Link
    Cars hacked through wireless tire sensors
    By Peter Bright | Published 12 months ago
    The tire pressure monitors built into modern cars have been shown to be insecure by researchers from Rutgers University and the University of South Carolina. The wireless sensors, compulsory in new automobiles in the US since 2008, can be used to track vehicles or feed bad data to the electronic control units (ECU), causing them to malfunction.
    Earlier in the year, researchers from the University of Washington and University of California San Diego showed that the ECUs could be hacked, giving attackers the ability to be both annoying, by enabling wipers or honking the horn, and dangerous, by disabling the brakes or jamming the accelerator.
    The new research shows that other systems in the vehicle are similarly insecure. The tire pressure monitors are notable because they're wireless, allowing attacks to be made from adjacent vehicles. The researchers used equipment costing $1,500, including radio sensors and special software, to eavesdrop on, and interfere with, two different tire pressure monitoring systems.
    The pressure sensors contain unique IDs, so merely eavesdropping enabled the researchers to identify and track vehicles remotely. Beyond this, they could alter and forge the readings to cause warning lights on the dashboard to turn on, or even crash the ECU completely.
    Unlike the work earlier this year, these attacks are more of a nuisance than any real danger; the tire sensors only send a message every 60-90 seconds, giving attackers little opportunity to compromise systems or cause any real damage. Nonetheless, both pieces of research demonstrate that these in-car computers have been designed with ineffective security measures.
    The Rutgers and South Carolina research will be presented at the USENIX Security conference later this week.
  5. Musashi
    Good read, thanks for posting it!
  6. SurlyOldManMN
    Nothing new, frighteningly enough...
    There was a good conversation on another forum about using the TPMS to coax people in to pulling over, which is where the fun can start. Turns out "closed" systems in your car aren't all that closed.
  7. pillboy
    Time to wrap my car in tin foil.
  8. ofspunk7
    Best idea ever
  9. SurlyOldManMN
    Just remember you said that... ;)
