headlight and fog light alignment
Discussion in 'Modifications And Maintenance' started by 02blubru, Jun 30, 2006.
  1. 02blubru
    Norwood Young America
    How do I do this on an 02 WRX?
  2. Dizmal
    Dizmal Well-Known Member
    In mah Forzda, yo
    Fog lights have a srew you tighten or loosen. Its right behind the fog light on the inside top corner. I believe turning it towards the passenger side lifts the spot up.
  3. 02blubru
    Thanks Dizmal
    anyone else know how to do the headlights?
  4. TSTRBOY2004
    possibly the same way... look for some screws that have a spring in the assembly.. the will be the adjustment screwsssssss
  5. 02blubru
    Well, it is easy, there is not screw with springs, but there was a screw with a a gear on it connected to another gear that when turned raised and lowered the light. Thanks, dizmal, and wrxboy2003
