Headlight Clearing sealant
Discussion in 'Modifications And Maintenance' started by sapalas, Oct 25, 2007.
When clearing headlights use the existing sealant or apply new sealnt to the housing
Poll closed Oct 26, 2007.
  1. Go ahead and use the existing sealant works just fine.
    40.0%
  2. Clean it up and apply new sealant Do it right the first time
    60.0%
  1. sapalas
    sapalas Well-Known Member
    I am going to clear my headlights Tomorrow and want to know what would you do, use the existing sealant or go buy the 3M strip sealant.
  2. mnstilynwrx
    mnstilynwrx Well-Known Member
    just do what it takes to make it look nice... you will be happy in the long run. plus ya gotta represent man. None of this poorly put togather stuff! hahaha good luck
  3. Bielke55
    Just heat up the old stuff and it'll be just as good as anything new.
  4. Scuba Steve
    Neither. After taking apart the lights you should assess the condition and amount of the original sealant. I've worked on lights that did NOT have a enough left to warrant putting it back together without adding a new coating. bad idea.
    So, your answer is this....You don't need to replace the original sealant, but you MAY need to add more if there are sections that are bare or have a minimal coating.
  5. blackozone
    +3 Bingo. I've ripped headlights apart many times, and this is the method I've used. No problems.
  6. tangledupinblu
    x4! I'd go to Napa and pick up their: "Permatex" Black Silicone Adhesive Sealant, item #81158 16B. It's about $4-5 bucks and works great!
    But if there is enough existing sealant, you may not need it. I personally like to add a little fresh stuff all the way around just to be safe. Don't want any moisture in there.;)
  7. Shibbs
    DO NOT USE SILICONE.
    Get the 3m Strip-Caulk.
  8. AWDimprezaL
    Permatex Plz!
  9. blackozone
    I believe RTV works well, or weatherstrip adhesive. Anyone feel free to enlighten, but it seems like RTV that's in there from factory.
  10. Shibbs
    It most definitely isn't a silicone. Its more of a sealant that never really cures/hardens. That's why it bakes in the oven at 200 degrees to soften it.
  11. Shibbs
    NO NO NO!! I used the 3m weatherstrip adhesive on mine and when it cured it left white powder on the inside! It makes it look like there's moisture on the inside!
  12. blackozone
    It was RTV that I used on my color changes, not weatherstrip adhesive. I haven't had an issue with any "powder". I will have to look into this more though. Thanks for the heads-up.
  13. driftin240
    driftin240 Well-Known Member
    I (Jason) used "The Right Stuff", which is a black silicon. Works great, no moisture, no powdery substance.
  14. driftin240
    When I did Greg's (RallySTI) STi headlamps, I used it again. Once again no moisture and no powdery junk. It seems to hold up to severe temp changes, and all kinds of moisture.
  15. shineynitelite
    the right stuff is just heavy duty standard permatex rtv
