Hella Supertones
Discussion in 'Modifications And Maintenance' started by MNAutomatic, Sep 12, 2004.
  1. MNAutomatic
    MNAutomatic New Member
    Well I am starting to get my parts in and these are one of them. I am really confused on the wiring and reading all the posts talking about the install of these horns just makes me even more confused. I passed you discopope one day on the highway, atleast I think it was you, and noticed that you or whoever that was had installed these. Anyone else got any tips on installing these or can provide me with a very clear simple diagram of how to do it. I am really excited to test them out
  2. DISCOPOPE
    DISCOPOPE Well-Known Member
    i just used the stock relay, and wired them to the stock horn leads.
    to get the grill off there are 4 little push clips on top, and two on the sides that you have to press down with a screw driver..
    there are already two holes in the center brace, one is used for a temp sensor, you can just add it to the bolt, it' all fits well.
    so, hot wires to the hot terminal, then i took a ground to a hole right up in the radiator frame.
    the stock relay has plenty enough juice to make them hoot.
    i tried the hella relay and almost loaded my pants. :D
    if you do use the hella relay, i think our horns are wired with the ground switched. (this is how i scared the *** out of myself)
    make sure you use good crimm treminals, and dilectric grease on them, as well as the back of the supoertones.
    also heat shrink tubing is a must.
    i can pop off a picture tomarrow.
    also i have some 16ga wiring and teminals if you need them.
    just let me know and i can drop some in the mail.
  3. DISCOPOPE
    i was going to take a pic over lunch, but forgot i put a bling bling carbon radiator plate on... i'll see if i can get one tonight and post it tomarrow.
