96 Honda Accord EX 4cy. AUTO with 99k miles. Just pick up this accord and forgot to check the door locks. When I lock the doors, within about 5seconds the door will automatically lock it self again. It'll do this every 5-10sec constantly. If the doors are unlock it doesn't do anything(stays normal). I've tried removing the "door lock" fuse and replace it. It works for a day and now its coming back. Also, i tried reseting the ECU(disconnect battery) and it still doesn't change anything. I thought it might be the door switch so I remove each door switch at a time and lock the doors, it still has this problem. So forsure its not the door switch. Now I'm out of ideas and frustration is kicking in. Any advice would be appreciated. What else should I check?
Which door is unlocking? All? or just the drivers side. If it is just the drivers side. Put in a drivers side door lock actuator. Common problem with the older hondas having this issue. Have a nice day!!
