help. car doesnt want to idle
Discussion in 'Modifications And Maintenance' started by LilRed, Oct 13, 2005.
  1. LilRed
    LilRed Well-Known Member
    hey i justed changed my plugs and now it barely wants to run. in the low rpm it wants to kill and past about 2g and it run ok. any idea on whats wrong?
  2. Speedemon
    Speedemon Well-Known Member
    i am going to go out on a limb and say the plugs
  3. LilRed
    damn it! they are new! i hope not cause my old ones look bad!
  4. Speedemon
    what ones did you get
  5. LilRed
    autolite
  6. readymix
    IBplugsareyourproblem
    Did you gap them properly?
  7. Dynapar
    yes gappage is important. too much gap and you will blow out the spark. (most likely problem)
  8. LilRed
    they are supposed to be already gapped. and second i dont have a gauge to gap it.
  9. readymix
    bad answers, both of them. Never trust the pre-set gap on spark plugs, and always have a gap gauge when you do it. THe gap gauge is like 99cents at Autozone. Pull them out, tap 'em, gap 'em, put them back in, start your car and let it sit for a couple minutes.
  10. Dynapar
    who knows what the gap should be on the plugs for a 2.5RS?
  11. Squiggly
    Squiggly Squiggly
    i had the same problem when i put my new ones on..i took all of the plug wires out and put them back on and it fixed it.. i guess one or two wernt on all the way
  12. LilRed
    found my problem! it was a vacuum leak right after my maf. i guess it popped off when i was driving it hard.
  13. kickin_81
    kickin_81 Well-Known Member
    Great! Glad you got her running again. Usually things like that happen when you work in an area with lots of things that you touch. It's also strange how no CEL got triggered in a situation like that.
  14. morganm
    morganm New Member
    Glad you fixed it.
    I'd still get a gap guage. 99 cents at the parts counter. I buy pregaped plugs and always check them before going in. Rarely are they uniformaly gaped precisly to specifications.
  15. Dynapar
    hmm.. that has happened to me before. except i had a small one pull off the cruise unit, and would idle for a bit then die on me at intersections.
    good to hear you got it up and running though!
  16. LilRed
    thanks guy for the help though
