HELP!!! COMPUSTAR problem
Discussion in 'Off-Topic' started by sgrtits, Jan 25, 2012.
  1. sgrtits
    sgrtits Well-Known Member
    So my key fob would. Not unlock my door when I left the dentist so I used my key to unlock my door so now I can not start my car and I am stuck here and bilknutz will not answer his phone plz someone call me if you know how to fix this other wise I need to get towed....
    952-452-0980
    -kalie
  2. JasonoJordan
    Try taking the battery out of the fob and putting it back in. Then lock and unlock the doors. What happened is you basicly told the alarm the car has unauthorized entry because the alarm is still engaged it has set your imobilizer. To reset it you will need to cycle the locks. you can try to do it manually from inside the car as well.
  3. sgrtits
    Imy key fob is the 1 way and you need a mini screw driver......
  4. sgrtits
    And I don't know how to do it manually I'm retarded when it comes to this kinda thing
  5. sgrtits
    Some one please call me
  6. JasonoJordan
    i pm'd you.
  7. subaruordie
    subaruordie Well-Known Member
    I also used my keys to open the door once and had the same problem u did. I had to unlock and lock it from the inside then it worked.
    I had the compustar 2 way system installed in November and it has been nothing but a pain in the butt since I got it. Mine has locked itself with the keys in it a few times but usually unlocks itselfs 5-10 minutes later. And it constantly needs reprogramming. And it never remote starts the car when it 10 degrees or less so kind of defeats the purpose of remote start.
  8. JasonoJordan
    We got her sorted out. Turned out to just be a very corroded positive battery post.
  9. subaruordie
    Yup that'll do it too hah.
