sorry to be so urgent but i'm supposed to do something for the MIL today and she's 150 mile round trip! so, after getting our headgasket replaced several months ago and all was fine i looked at the overfill tank and the level was low. crawled under and saw the coolant is leaking from both ends of the cam cover (ft cover that covers timing belt). also, i checked the oil and it was down a quart. [it uses a little oil so i check frequently] here's where it gets tricky--i overfilled the oil several days ago by a good 1/2 inch on the stick. i thought it would good use it up but i have been concerned. do you think i could have blown a seal that could be causing the coolant to leak out? is there a seal that when blown can cause the coolant AND the oil to leak out? thanks for any info, but i'm trying to see if this cant wait until Monday when i can get it to the shop... jim
Only way to have coolant in the timing cover is the water pump leaking (should have been replaced with HG's so I would doubt it but...) or the upper rad hose is leaking down into the timing cover. I would check around the upper hose at the block and make sure the clamp is positioned correctly and tight. Hopefully thats all it is.
thanks Threshld1! i will check my receipt to see if they changed the wp...as you say seems like they should have? and i will check those hoses and clamps to
low oil and low coolant, sounds like a bad headgasket. thats the only seal that would cause low oil and low coolant is the car smoking at all?
no smoke. man, i hope that's not it! if it is it should still be under warranty. i still need to check the hoses which i will do in the am tomorrow. if its a water pump do they leak a pretty good while before going out totally? i really need to go on a 150 mile trip tomorrow to my MIL's
well I found a leak in that top hose! it needs to be replaced but at least I can tighten it up and get to the MIL's...thanks for the input guys
yea, but is it normal that you can go 150 miles rt on a bad waterpump? most of the oil is being burned through the tailpipe but there is a valve cover gasket leak or something going on?
i havent seen any leaking in last two days and i believe the leaking hose was the issue. sure glad of that
