Help: Fog Install Problem - No Voltage
Discussion in 'Modifications And Maintenance' started by mlgez, Apr 30, 2006.
  1. mlgez
    mlgez Well-Known Member
    I was starting to install the OEM fog lamps that I got firday (not new). The problem I am having is that I am not getting any power on the connectors in the car at the fog lights. I borrowed (stole from wifes car) the fog light switch. I turn the headlights on low and push the button. The light comes on on the switch and no voltage at the connectors. I checked across both wires and then I check each wire to ground, nothing.
    I checked in the fuse box and the fuse is in there and is good.
    Am I missing a relay or something? I did not see any in the underhood box for fogs.
    Any ideas?
    2005 STi
  2. bikerboy
    Yes you are missing a relay. If you open the cabin fuse box and look to the right of the standard fuse pannel you will see the relay block. There are two open spots the top one is for the heated seats, the bottom one is for the fogs.
  3. mlgez
    Sweet! Thansk a lot. Hope the dealer has one tomorrow.
    Figured it had to be something simple. I need to get service manual on this car!
