Help for the pizza guy.
Discussion in 'Modifications And Maintenance' started by IamUnInc, Sep 19, 2006.
  1. IamUnInc
    IamUnInc Well-Known Member
    St. Paul
    Hey my buddys alero just wont start. When he turns the key it turns over and a little exhaust comes out the back but then it dies right away. Any help would be great. Thanks
    -Nick-
  2. TSTRBOY2004
    spark, fuel,????? does it start then die or just turn over with no start... if you try too much you can burn out the starter as well....
    check spark then for fuel...... fuel pressure next.. etc etc
  3. Scuba Steve
    In the Co-Driver Seat
    was it running fine previously? and symptoms leading up to this?
    check for the basics...
    loose ground wire?
    condition of the fuel filter?
    spark plugs in good shape?
    Ignition system in good shape? wires? Coil(s)?
    I've had luck by disconnecting the battery for a few minutes, connecting it back up then trying to start it.
    good luck...
  4. kvang
    kvang Well-Known Member
    St. Paul
    Plugged Cat. convertor???
  5. IamUnInc
    St. Paul
    It just stoped working. Two days ago it worked and yesturday it didnt. When i try starting it it seems like it wants to start for a sec and then it just kills. I cant get it to fully start. Im going back over to his place today to check spark plugs and all that good stuff.
    -Nick-
  6. hofit
    hofit Well-Known Member
    MN
    Does it catch at first and then die out? Maybe the fuel pump is pressurizing when the key is turned and then it starts but can't keep up so dies right away. Just a guess. If it's the plugs it would have a hard time catching in the first place right?
  7. IamUnInc
    St. Paul
    Yeah it catches at first and then just dies right away.
  8. predavore
    predavore Well-Known Member
    Southern 'Burbs
    My girlfriends Tiburon did that, but showed symptoms more slowly. It was the FPR.
    -DH
  9. hofit
    MN
    It's probably fuel delivery then. Like the response above, FPR or pump.
