Help identifying spring clips for console
Discussion in 'General Subaru Discussion' started by toyotanos, Oct 9, 2014.
  1. toyotanos
    toyotanos Well-Known Member
    Hi guys, I'm working on a 06 center console swap and have run into an obstacle- I need 4 of these clips to create threads to fasten my manual climate control with screws where the auto climate used plastic clips. Thre are 2 on the console support already, so I know they'll work. A part number or part name would help greatly, alternatively if you have 4 spares I'd like to buy them from you.
    Picture of part:
    https://lh4.googleusercontent.com/_dBi2DNoG4Oo/TY_Yu-WttmI/AAAAAAAABcg/jPWKfxan6kw/s640/IMG_0236.JPG
    Picture of support with 5/6 clips installed (small pic, look for the silver bits)
    http://thumbs1.ebaystatic.com/d/l225/m/mZw4aa5rblTj0wIgFKWT3Cw.jpg
    Thanks for any help you might have!
  2. Sjogun
    Sjogun Active Member
  3. blackozone
    I did the same thing. I improvised and used zipties to hold the bottom two tabs down. They've held for years and never had an issue.
  4. toyotanos
    That's probably what I'm going to do if I can't find the proper clips. I will have to use the existing clips for the lower climate mounts since there's little space for a spring clip, the upper and lowermost ones have adequate space, though.
  5. spudd
    spudd Well-Known Member
    Sorry again I couldnt help ya out steve
    toyotanos likes this.
  6. toyotanos
    No worries, I found a couple inserts that might work from Toyota land- I'll let y'all know if they work out!
    CarpalTomO and spudd like this.
