Help just picked up a 96 CBR
Discussion in 'Off-Topic' started by rabbit, Jun 11, 2011.
  1. rabbit
    rabbit Well-Known Member
    Picked it up yesterday but won't idle or stay running without the choke on. Bike has 17k miles, was in storage since last year. Is it hard to clean carbs? Im completely clueless to bikes.
  2. Jackstand
    Jackstand Well-Known Member
    It is the carbs the jets are probably clogged
  3. AWDimprezaL
    plugged pilot jets, 100%
  4. rabbit
    Is it possible to clean the carbs with out removing them from the bike?
  5. Dirtyracin
    Dirtyracin Member
    Not a good clean
  6. AWDimprezaL
    *Not a clean that will accomplish anything.
  7. redprzdent311
    Removing/cleaning carbs is one of the easiest things to do for small engine maint. You're going to need to learn how to do this frequently if you want your bike to last so I recommend getting on a forum and figuring it out. You just have to make sure you don't lose any pieces and putting them back together is quite simple.
    Oh, and make sure you wear a helmet too.
  8. predavore
    predavore Well-Known Member
    I did it a couple times on my old R6. Getting the carbs out was harder than cleaning them...
  9. rabbit
    Thank god for youtube. Found someone with step by step on how to remove the tank and carbs. Will post pictures up when all is finished on this bike.
  10. PRA4SNO
    PRA4SNO Well-Known Member
    Rock on!
    Spend some money on a set of good gear, and make sure you've got good tires. MSF courses are GOLD too. I know its not the "cool" thing to do and doesn't get you onto the road any faster, but they will make you a much happier, safer, and more competent rider in a way that doesn't involve a hospital bed.
    Enjoy the summer before its over, it goes too fast!
