"help Me" Fuel Cut When Wrx Turbo Spools
Discussion in 'Modifications And Maintenance' started by demong, Sep 21, 2007.
  1. demong
    demong Well-Known Member
    Hey,
    i'm having a serious problem with my car and I'm still finding the actual source of the problem.
    I drive a 2002 wrx with a stage 2 reflash with a full turbo back and equal length headers.
    The problem is that there is an immediete fuel cut when the turbo spools or when the turbo pressure meter goes above zero psi. I can reach 70 miles per hour but at a very slow pace because I can't kick in my turbo. When I try to spool the turbo, the vehicle immedietly seems to slow down.
    This happened yesterday and it was a highway struggle on my way home.
    I can still run the car as I have to manage the wrx RPMS so that it doesn't actually activate the turbo.
    There is a out of the ordinary whining sound when I start my vehicle near the rear tires.
    My friend Pheng who drives an STI assumed that my fuel pump is dying.
    My friend Fong who drives a forrester XT recommended me to check all the air lines or the turbo intakes for any leaks. So far, no leaks and its been checked already.
    My other friend Lou who drives an RS said that it might be because of bad gas and that I should burn off all the gas and repump octane 92.
    Could it be the MAF sensor that measures and balances the air fuel ratio.
    The oil light or engine light doesnt come on at all during driving.
    Whenever I step on the gas hard to bring in turbo pressure for the car, the car immedietly decellerates and fuel is cut, whats funny is that I have to switch gears to RESET this and the car starts working again.
    It ran fine yesterday morning until after 4 pm, tank was at 3/4 full, I ran up to 2nd gear and pushed it to 4000 rpm and then I had immediete fuel cut, i thought my clutch was slipping and it wasnt.
    Right now it's running the SUPER AMERICA gas.
    Any reasonable explanation would help so much.
    thanks, mnsubaru!
  2. Bielke55
    Hopkins
    I think you have a nasty hole in your fuel mag
  3. AWDimprezaL
    Monticello.
    i bet your EGT sensor is funked
  4. Bielke55
    Hopkins
    Fuel pressure regulator?
  5. demong
    thanks for the early quick response, I'll take your advices into consideration.
    if my car survives the day,
    i'll bring it up to Firestone at Midway.
    thanks guys
  6. BBsRS
    BBsRS Well-Known Member
    On the Road
    Change your oil lately??? Low oil pressure or old used watery oil causing spuddering of oil over valvetrain or sensor. Car may be reading that its not up to optimal performing conditions hence trying to save itself from exploding but means of fuel cutting. This is known in the world of other makers such as Honda AKA LIMP MODE!!! keep us up to date on what this is. I wonder if subaru has limp mode? anybody?
  7. Bielke55
    Hopkins
    Subaru only has a default mode when it has a check engine light.
  8. demong
    Quick update on my way to work
    It can't rev past 3000 RPM.
    whenever I press hard on the gas paddle on any gear, i can't pass 3000 RPM.
    immediete decceleration at 3000 rpm.
    runs fine below 3000 rpm.
  9. demong
    Bbsrs
  10. Bullwinkle
    Saint Paul
    Subaru's do have a limp mode (actually, a couple variety's), one of which will disable boost control if the car is knocking very badly.
    However, he'd probably still be able to get up to WG pressure if that was the case.
  11. TSTRBOY2004
    Car Is blacking Out Under Boost!!!!
  12. frichdan
    frichdan New Member
    Robbinsdale, MN
    Maybe this will help, I recently had an issue I just had with my 02 WRX that might be along the same lines. My car would idol fine. I could drive it ok, when I would try to "gun it" or drop gears on the freeway or just try to speed up some, it would seem to lose power/slow down/just sort of die/choke out on me. When I took it in, the found that my Ignition Coil was Faulty, hence the losing power/shutting down a lil. Quick fix, they ordered a new one, 20 minutes to replace, and $150 later my car is fine.
  13. LSE Performance
    LSE Performance New Member
    Ramsey, MN
    Multitude of possible issues:
    Fuel delivery
    Ignition
    Tune
    Mechanical problem such as boost leak, MAS, turbocharger.
    I would recommend bringing it somewhere for DIAG versus just throwing parts at it.
  14. Scuba Steve
    In the Co-Driver Seat
    Ohhhhh you're too funny:biggrin:
  15. BBsRS
    On the Road
    Sounds to me thats its alot like the honda's except that they choke, bog, fuel cut, rev limited, etc..etc..etc.. at 4000 rpms. Could be anything along the lines of what LSE mentioned in the posts above. A buddy of mine had the same problem in his honda and brought to my attention. After a few days of checking the car over it came down to the fact that he hasn't change his oil in a while and so it was old and water like and very low. This caused the oil to splutter over the valve train and not lube as well, and seeing that it was a honda with vtec not a subaru with turbo right when the vtec was about to kick in BOGG, fuel cut what ever you get the idea. by the way you still haven't mention when you last change your oil? It could be that simple!!! if i remember right your car should take 5 quarts + alittle maybe even. I know my N/A takes alittle over 4, about 4.6 quarts or so to be full accorking to my oil dip stick in my car. I don't know about others though so people don't come after me about how much oil goes into my car. Mine just takes that much to be happy. =)
    looks like frichdan had the same problem as well. That would be a very good start i would think. It'll all come down to maintainance and check ups wheather you do it (trial and error) or pay the shops to.
  16. demong
    hey, the last time i got an oil change for the vehicle was when my friend had it, i think he changed it around spring. the 2nd mile guage reads 2800 miles running on synthetic oil. im going to go ahead and get an oil chang for it asap when i get off work. i sure hope that fixes the problem. will keep you guys updated. but hey, you guys rock and thanks for the help. this is my first subaru.
  17. ej20
    ej20 Well-Known Member
    I agree on the Oil Change. Its been about 7-8K miles on my 02WRx since I havn't do my oil change. I do notice a lot in performance of the car. It feels like the cars powerband is so ROUGHT, doesn't have that smooth reving feeling like when the oils are new. Need to do oil change this weekend.
  18. ej20
    omg, now the cars blacking out too......hehehe..
    ohh we just love having you around Nate.............................
  19. readymix
    Eloh, El
    I may be wasted, but I'm absolutely positive that not one word of what you just said forms a complete thought. At no time did you're post even come close to answering a question. I award you no points, and my god have mercy on your soul.
  20. demong
    Oil Change is complete but still having major issues
    After work, i did an oil change,
    stuck in some Mobile 1 5w30 fully synthetic into the vehicle and changed out the oil filter.
    Lightly ran the car around the block to filter in the new oil through the engine.
    then I started to rev it up.
    Same problem still persists.
    To take it towards a deeper thought, i guess it isn't RPM limited. Everytime I press hard on the gas, fuel is immedietly cut off. I have to press very lightly on the gas to get the vehicle to run.
    here is the RPM max on each gear.
    1ST GEAR 4K RPM UNDER ZERO PSI
    2ND GEAR 3K RPM UNDER ZERO PSI
    3RD GEAR 3K RPM UNDER ZERO PSI
    4TH GEAR 3K RPM UNDER ZERO PSI
    5TH GEAR 3K RPM UNDER ZERO PSI
    Has a struggle from 45 mph towards highway speed of 60mph.
    Could it be the fuel pump??
    when I start up my car, it makes a recognizable whining sound, "fuel pump possibly" then it fades away in 2 minutes.
    When I press hard on the fuel paddle, it bogs down or decellerates. I have to lightly press on the gas to accelerate.
    Any ideas, clues, suggestions please.
    thanks
  21. TSTRBOY2004
    why am I not surprised... never have I heard of that problem with the oil!!
    the fuel pump usually makes some noise but if it is making noise till 2 minutes or so then maybe it is on its way out.. but is that the cause... slightly doubtful....
    if it is doing stuff when you are applying or having to un-apply then I would maybe think it could be the TPS playing games?? but that is a guess...
    as someone has stated... save yourself money in the long run by not blowing up your engine by driving it hard trying to figure out things and just pony up and get it looked at by a GOOD shop....
  22. demong
    My friend Fuji_K is on vacation fishing, I have to wait until Monday until he gets back so i can do a full diagnostics and inspection in his garage.
    I guess your right, i should be careful not try to blow up my engine.
    I kinda hope that some new octane 92 would fix the problem for my wrx.
  23. LSE Performance
    Ramsey, MN
    Again,
    Fuel delivery
    Ignition
    Tune (metering issue)
    Induction system
    Your problem lyes in those systems.
  24. AWDimprezaL
    Monticello.
    this is exactly what happend to a trade in that was totally beat up and was missing the EGT, any codes?
  25. subytek
    subytek Well-Known Member
    Further west than Ted.
    He said there is no CEL. Is there a aftermarket intake on the car?
  26. LVT
    LVT Well-Known Member
    t3h f4sT
    it's your spark plugs, change them and call it a day! actually, i'm at home now from fishing come over if you want me to look at it or call me.
  27. FuJi K
    St. Paul, MN
    closest would be coilpack probably.
    The car DOES NOT have an exhaust note when it bogs down. A/F meter reads LEAN when it's bogging and engine RPMs slowly dropping w/ throttle position 75%-100%. Engine can REV with 1-10% throttle but cuts at 4k-rpms. Engine cuts more if more throttle is applied.
  28. AWDimprezaL
    Monticello.
    cam sensor?
  29. demong
    Oh yeah,
    forgot to mention that the maf sensor connection was removed and tested.
    Interesting how the vehicle reacted the same way in safe mode with the maf sensor removed.
    Cuts fuel at 2500 rpm.
    Plugged the maf sensor back on and things were still messed up with my wrx.
  30. demong
  31. demong
    Does anybody know any links for a coil pack or is the coil pack also known as the ignition coil.
    I sure hope I can get my vehicle running well after I reinstall new spark plugs otherwise I might end up with a few hundred dollars of 2002 wrx spare parts.
  32. Substeroo
    Substeroo Well-Known Member
    hmmm... vacuum line leak? TPS sensor? Does it idle fine?
  33. demong
    it idles fine, no abrupt jumping RPM meter.
    but when I gas it at neutral, it bogs down or fuel cuts at 4000 RPM.
  34. Substeroo
    Coil pack = Ignition coil
  35. Substeroo
    I don't know for sure but check your vacuum lines.
    Did this start out of nowhere? Can you think of anything that you did to the car just prior to the problem starting?
  36. Nuke
    Saint Paul
  37. WRX1
    Over there
    Why don't you do the simple thing and log it. You are not sure if it is a fuel cut, and you can't tell until you log it. It couple be your FPR and it dumps TONS of fuel as soon as it starts to ramp up. Is this a rpm thing, or a boost thing??
  38. TSTRBOY2004
    if you are gonna throw $110 at something that you have NO idea if it will even solve your problem spend the same damn money and get it inspected by someone who can help work it out...
  39. subytek
  40. subytek
    Once again, does it have an aftermarket intake?
  41. driftin240
    driftin240 Well-Known Member
    Out West
    What mods are on this thing, if any?
  42. driftin240
    Out West
    That wasn't very clear in his post. Sounds like it's more load effected than RPM effected. If it were a coil, it would more than likely still rev, but rev very slowly under any load.
    Sounds to me like you may have a bad front oxygen sensor, but then again...your car idles fine.
  43. frichdan
    frichdan New Member
    Robbinsdale, MN
    I agree! A lot of people up here have good ideas... But, you obviously don't know enough about the car to fix it yourself... no offense, hell, I don't know enough about my car, so I tend to take it in a bunch! But that saves me time. Just pay the $110-150 to have someone who knows what they are doing take a look at it! Unless you like not knowing what it is for sure and like guessing at the issue for weeks!
    Just take it in!
  44. WRX1
    Over there
    Of course he could just have another member log his car for him and that would be free.
  45. subytek
    No, lets just keep throwing parts at.
