help! no spark!
Discussion in 'Modifications And Maintenance' started by wagonL, Apr 17, 2007.
  1. wagonL
    wagonL Well-Known Member
    got my engine in my impreza..got all the wires hooked up and tried starting it up. fuel pump works starter works compression is good on all cylinders. but i have no spark..help anyone???
    so...what could be the problem? anyone???
  2. AWDimprezaL
    Crank sensor? cam sensor? ecu? dead coil? check all these
  3. curly2k3
    no coil, its coil packs on plugs... check the harness that the packs plug into, then check ECU connections
  4. AWDimprezaL
    most def check connections...my car broke down when one of the main connectors came loose
  5. wagonL
    everything is where its supposed to be...argh! man...this is frustrating...!!!! what else can it be...what can go wrong that wont let it spark???
  6. wagonL
    can you get any wiring diagrams? for the 95 1.8L? the bulk harness??
  7. AWDimprezaL
    have you hooked up a scan tool?
  8. AWDimprezaL
    no, not that i know of
  9. wagonL
    well..im goign to go back and try it again....so...(crossing fingers) checking my wires again...and then going to crank it again...
  10. curly2k3
    my bad, i thought you were talking about the EG car
  11. AWDimprezaL
    he is
  12. Chux
    sorry, I don't know anything about the car you're running. is it a swap?
    you say the fuel pump works, but how? do you have it wired correctly (via the ECU)? or do you mean if you manually give it power, it pumps.
    I think the fuel pump circuit is a great indicator of whether or not the ECU is wired up correctly.
  13. curly2k3
    are you getting ignition at all? if the answer is no, check the harness and the connections again, check the plugs when your cranking it over and see if your even getting a signal. i know i had dead coil packs on 2 cylinders, fairly common on EG33's... also, check ALL of the sensor connections, its easy to overlook something small... if its getting any spark at all i would look towards coil packs or even something as stupid as the MAF and O2 sensors and their connections, mine have given me problems in the past. hope you can figure it out soon man, if your still having some problems give me a shout later, you got my cell number.
    Chris
  14. wagonL
    ok..now...when i tried it...my ecu fried! yikes!! well..i guess i have to get a new ecu and new wires! darn it....but i guess its fine now...so...thanks though everyone...
    dao
  15. FuJi K
    nyah! lol.... I thinks I going to send in clutch pressure plate.....
