Im doing all the breaks in the legacy and i need to know what size that nut is to take off the rear rotars! Someones is comming by to bring me to the store and i need to know what size socke to get! THANKS 96 legacy l wagon!
Get a metric set that has the following sizes: 8, 10, 12, 14, 17, and 19. About 99% of the normal bolts on a Subaru are this size. The caliper bolts on mine are 12mm. The bracket bolts (sometimes you need to loosen them up to get the rotor off) are either 14 or 17mm. The bleeder valve is an 8mm.
I got all that. i need the socket size to get the whole rotar off!! That big nut in the center off the rotar
F!@!!!!! I am a TOTAL NOOB!!! ITs easier to get the rotar off if the e-brake isn't set!! LOL THANKS FELLAS
I was wondering why you would take the big nut off when it has nothing to do with the rotor staying on?!?!?!?
1-1/4" works pretty well, 3/4" not so much, unless you are talking about 3/4" drive, which works great.
