my 04 sti has some sort of problem.... when i'm pulling out of the driveway or practically backing up the car, there is a clunking noise when i press on the brakes... this happens every time when i press on the brakes... i have no clue on what the problem is... can anyone help me out???
I think he meant to check them again, do you have any idea where the sound is coming from, is it a tinny sound or more solid?
its a more solid CLUNK sound... and i believe its coming from the rear end... you think it might b my differential?
Make sure your pad bad didn't come loose or the hinges that press in from the top isn't loose that is.
^^^ most likely cause... 2nd step... pull wheels off rear of car adn retighten every bolt in the calipers etc.. process of elimination... 3rd... take it so someone to look at...
