MAPerformance is now starting to take resumes to fill a production fabrication position opening up in the very near future. This is a full time position (40-45 hours/week). This particular position will involve a lot of 16 gauge piping fabrication/fitting, and most products will be fully TIG welded on both stainless, and mild steel. Overall fit/finish, and attention to detail are held to a high standard, as well as the time lines set for incoming orders. Pay will be determined based on past experience, and overall fabrication skill and knowledge. Requirements for consideration are as follows: -Knowledge/passion for the aftermarket automotive industry is what we're all about -Previous welding/general fabrication experience is a must -Strong TIG welding experience -Aluminum welding experience is a plus -VOTECH/other schooling is not required, but is a very big plus -Your own mask and gloves (any other safety equipment is fine, but safety glasses will be provided) -Ability to work both as a group, and individually in a shop environment Please e-mail your complete resume with contact numbers to [email protected] with ATTN: CHRIS B in the subject line, or drop your resume off at our shop located at: 9905 13th ave n Plymouth, MN 55369
normal work day is 9-6... although from time to time there may be evenings you would need to stick around to finish a project.
