help with non-subie
Discussion in 'Off-Topic' started by Scuba Steve, Nov 23, 2006.
  1. Scuba Steve
    1996 dodge caravan with automatic transmission
    just had a new tranny installed and got it back from the shop. now the car shakes horribly under acceleration (coming from the front) like the front is way out of alignment. It does NOT shake and is smooth when coasting. On top of that during right turns it sounding like the left axle is clicking.
    anyone ever run into this type of problem?
    how did they screw this up?
    FYI: it never had front end issues before and the entire front suspension was replaced by me last summer...no issues until we got it back.
    thoughts?
    any help would be appreciated.
  2. kvang
    kvang Well-Known Member
    It could be a couple of things. Maybe a loose axle nut, lower balljoint, tie rod end.
  3. hercules
    hercules New Member
    CV axle and tranny mount???
  4. Iroc-Z
    Iroc-Z Well-Known Member
    A cv axle can cause this symptom.
  5. Scuba Steve
    Thanks guys. I replaced the ball joints, tie rods, and struts last summer. I was also thinking they screwed something up when re-installing the axles. On top of that evidentially it will make a clunk when putting into reverse from park.
    Any other thoughts?
  6. Nuke
    i've had an axle nut loose once, didn't feel great, look at the nut, it wasn't screwed in all the way -_- (way to go nuke) so, i tighten down and fine
  7. AWDimprezaL
    ide be willing to bet its a problem with the cv...take it to the place who "fixed" it
