help with struts and springs
Discussion in 'Modifications And Maintenance' started by modsuby, Aug 16, 2007.
  1. modsuby
    modsuby New Member
    Hi i have a bad rear strut on my 96 impreza brighton and i was looking at getting a set of Kyb Agx struts. While i am replacing the struts i might as well get new springs. I was on ebay and saw 2 auctions that fit my car for cheap.
    one set comes with Vogtland (959505) German Made high performance Lowering springs http://cgi.ebay.com/ebaymotors/KYB-AGX-SHOCKS-SPRINGS-SUBARU-IMPREZA-RS-4WD-93-01_W0QQitemZ160147180383QQihZ006QQcategoryZ33590QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ShippingPayment
    and the other is just 4 struts http://cgi.ebay.com/ebaymotors/KYB-AGX-SHOCKS-STRUTS-SUBARU-IMPREZA-4WD-93-01_W0QQitemZ230161946882QQihZ013QQcategoryZ33590QQssPageNameZWDVWQQrdZ1QQcmdZViewItem.
    1. Has anyone heard of Vogtland springs?
    2. What springs do you have and do you like them?
    3. In the pictures i noticed that the struts look different but the part numbers are the same. Does anyone know what picture is right?
    All help is appreciated,
    jake
  2. Aegis
    I read that as "Vortigaunt" springs, I think I need to put the games down ...
  3. modsuby
    modsuby New Member
    haha:laugh:
  4. EtchyLives
    EtchyLives Well-Known Member
    If the Struts are the same setup I have, the reason they look different is that the rears are 8-way adjustable- (with the knobs on the side of the strut body), and the fronts are 4-way adjustable- (with the adjusting tabs up on the top of the piston) dampening.
    I have Ground Control Coilover sleeves on mine, and when I get them installed this weekend, I'll let you know what I think. (Note, mine are from a GC setup that are going on a BC Legacy).
    Vogtland springs... never heard of them. I would be willing to bet some serious cash that the same factory that makes them also makes either H&R or Eibach, though.
  5. Justin
    Justin Well-Known Member
    If you need any help with the install we'd be glad to help out at a very reasonable shop rate!!
    I was able to get my v8 jdm spec c suspension on my 96 impreza so that is an option to. You'll have to use the stock L rear top hats but other than that everything else is a direct swap.
    Justin
    www.grimmspeed.com
