Help With Tail Lights Please
Discussion in 'Modifications And Maintenance' started by curly2k3, Nov 24, 2007.
  1. curly2k3
    Silent Hill, Jackass
    alright, anyone got any more ideas? i replaced the bulbs, replaced every fuse in the car... it keeps popping the same fuse, sometimes it will last a few days, sometimes it wont last even 10 seconds. i tried for 2 hours yestarday to find the short and i couldnt get the lights to go out... then when i needed the car lastngiht the lights went out yet again. anyone have any similar issues, any ideas as to what it could be at this point? my thoughts were possibly a short in the fuse box or maybe a cut somewhere and its shorting out... but i couldnt find anything anywhere when i was looking for 2 hours yestarday.
  2. bikerboy
    on the water looking for the sandbox
    Year and model?
  3. curly2k3
    1998 Impreza Outback Sport Wagon
  4. bikerboy
    I would first inspect the contacts in bulb sockets to make sure they are not corroded. Then I would look at taking an ohm meter and check that none of the power wires have a short to ground.
  5. curly2k3
    yeah i cleaned out the bulb sockets and they looked ok now, but maybe i should work on those a little more even, i will also have to check the power wires for ground shorts. thanks
  6. Frogy
    Frogy Well-Known Member
    Eden Prairie
    do you have trailer wiring?
  7. curly2k3
    nope, all stock wiring with no trailer wiring, i dont even have factory optioned fog wiring. lol
  8. 95lwrx
    95lwrx Well-Known Member
    brainerd
    check you wiring that goes up to your third brake light, alot of the times on the wagons the wiring in that part on the pass side at the top of the hatch from going up and down so much the wires end up breaking, not sure if it would make your other lights go out too but its worth a shot. maybe a wire is grounding out up there.
  9. curly2k3
    yeah could be... thanks Ryan, definatly need to check that out, didnt think about the 3rd light
  10. 95lwrx
    brainerd
    no prob, when i got my wagon my rear def and 3rd brake didn't work, so i split open that boot over the wiring and found all of the wires were broken. but my lower brake lights still worked. but it's worth a shot.
  11. curly2k3
    yeah could be grounding out there or something
  12. AWDmadness
    AWDmadness Active Member
    what lights are goin out? just your tail lights? do the break lights still work?
  13. Jackstand
    Jackstand Well-Known Member
    St Louis Park
    if i remember correctly it is all of his rear taillights. However, the brake and turn signals still work.
  14. ruberdukwrx
    ruberdukwrx Well-Known Member
    Tomah,Wi
    I had a similar problem and it turned out to be a bad markerlight switch
  15. curly2k3
    yeah, checked more grounds and wires today, along with the sockets...all looked good really, i am thinking it might be a switch, i loose the tail lights, just the running lights, i still have turns brake lights.
  16. gran0393
    gran0393 Well-Known Member
    Lost in the Burbs/Bugeye #005(RIP)
    what # bulb are you using...i know sometimes if you get the wrong bulb it pops right away
  17. curly2k3
    whatever Napa's computer listed it as i dont even remember off hand
  18. AWDmadness
    do you have a aftermarket radio in your suby? i had a problem just like this in one of my cars, check the illumination? wire on the radio. mine had grounded out and killed the running lights, but everything else worked. well hope this helps. good luck
  19. Shibbs
    SELL IT. Buy my WRX. :)
  20. Vorgto
    Vorgto BANNED
    >.< if your sick of that problem just get rid of that fuse and put a wire in its spot.
    Otherwise the cable probably tore or shorted with the twisting of your chassis.
  21. curly2k3
    aftermarket Subaru OEM STI stereo is all, i dont need a new car to mod eli.
  22. AWDmadness
    well i dont know what to tell ya, i had that same problem and thats what it was for me. did you have to wire it in or just plug in? I would check behind the radio maybe something is pinched or something. well good luck dude
  23. curly2k3
    just a plug and play, took less than ten minutes. i will be tearing into it more as i get time
