help with turbo upgrade please need your input
Discussion in 'General Subaru Discussion' started by prodrivesti04, Feb 9, 2010.
  1. prodrivesti04
    prodrivesti04 Active Member
    i have an 04 sti w/ stage 2 setup. k & n drop in air filter INVIDA downpipe to a blitz nur spec catless exhaust. also got an acessport tunning. on the acessport web page with the the set up i have it has 350hp to 385 lbs of torque. i am looking to upgrade my turbo and i was wondering what turbo out there would do me good vs my stock one. open to suggestion please help thanks
  2. 03subyR
    03subyR Well-Known Member
    Well you are looking into at least 20G and bigger turbos if you want to see more power. It depends what you want to do with a car dd, rallyx, autox, drag race or just ocational spirited driving. I think any bigger than 20G and you will have hard time spooling your turbo (~4k) and that sucks for everything but drag racing. 20G will give you about 20-25whp over your stage 2 set up at the same psi. You could reach that goal by switching to E85 and stock turbo. There are a few people here run E85 with STI turbo and get close to 300whp and 350lb/tq.
  3. piddster
    Slow down, holy hell.
    What do you ultimately want from your setup?
    And more importantly, what are you willing to spend?
  4. FuJi K
    what turbo depends on what you do with it. Engine setup should be built around the turbo. You want your turbo to max out, and not your injectors.
