Help!!!
Discussion in 'Modifications And Maintenance' started by k_thaosta, Jul 22, 2006.
  1. k_thaosta
    k_thaosta Well-Known Member
    Anyone have the special tool to take out the cam gears on the wrx? I need to take the heads off and if someone has another way of getting them off, it would help ALOT!!!
    thanks, Kong
  2. AWDimprezaL
    there is no special tool, take the timing belt off and leave the cam gears on, simple as that. or unbolt the cam gears, they arent held in by anything special, just a bolt.
  3. k_thaosta
    any easier way to get to the heads off?
  4. LVT
    LVT Well-Known Member
    easiest would be to remove timing belt and then heads.
  5. AWDimprezaL
    the absolute easiest way would be to take the engine out :)
