help
Discussion in 'Modifications And Maintenance' started by boomer, Dec 17, 2006.
  1. boomer
    boomer Well-Known Member
    I think my turbo is leaking oil.:emo: I stopped at target after a short warm up and drive and noticed smoke coming out of my scoop. I popped the hood and there was smoke coming out from under the heat shield. I have the tmic off and the heat shield off now but I don't see any wet spots on or around the turbo. Do I need to remove the turbo to get at the drain back line, and if I do remove the turbo do I need new gaskets to avoid exaust leaks? ('04 wrx wagon)
  2. boomer
    There is a bit of oil residue in my tmic inlet. I'm not sure if that's normal as I'm new to suby's and this is my first time removing the top mount.
  3. Iroc-Z
    Iroc-Z Well-Known Member
    Are you sure you are leaking from the turbo? Could be leaking from somewhere else.
  4. boomer
    It's possible but the smoke seemed to be coming from the bottom side of the turbo.
  5. chokin
    chokin Well-Known Member
    i had the same problem before...but not anymore....but my turbo isnt leaking at all, still in a good shape
  6. Shane86
    Shane86 Well-Known Member
    it could just be an exhaust gasket leak...
    is there any reason to believe your leaking oil? Oil spots on driveway? engine/underbody coated with oil?
  7. Se7enrex
    Se7enrex Well-Known Member
    did you use any product(wd40) to clean anything lately
  8. tangledupinblu
    Had the same problem last year. The smoke was coming through the hood scoop. When I would open the hood for a look-see I could see the smoke coming from the turbo/dp area. Don't know how or why, but it stopped on its own about a week later. No problems since, and i never did locate the source of the issue. But everything seems to be ok now! Good luck, you might want to wait it out a couple of weeks.:)
  9. driftin240
    driftin240 Well-Known Member
    Have you moved anything around lately..like your turbo or up-pipe? Oil feed and coolant lines shouldn't just start leaking.
  10. boomer
    Thanks for the advice everyone. I'm a bit embarrased but it seems that I was leaking oil from my drain plug. I forgot to use a new crush gasket when I changed the oil. It looks like some of the oil got on the exaust that's where the smoke was comming from. I feel like a bonehead but better this than the alternatives.
