Here you go Russ, GT30R specs
Discussion in 'Modifications And Maintenance' started by FuJi K, May 25, 2005.
  1. FuJi K
    St. Paul, MN
    Specs of GT30R turbo for STi Turbokit
    GT30R.
    56 trim comp wheel
    t3 turbo inlet
    4 inch intake .63 turbine a/r
    .60 comp a/r
    2.5 inch turbine outlet
    84 trim turbine wheel
    w/ theses mods:
    840cc injectors
    MY98 2.5L DOHC heads w/ slight polishing
    JUN 264 cams with valvetrain
    Crucial Racing Thermostat 160*
    EJ22T w/ forge pistons 8.0:1 CR
    Billet h-beam rods
    Hydra ECM
    Oil cooler
    aluminum radiator
    custom v-mount style radiator and IC behind grille
    Will I see close to 400whp on Mustang Dyno on 93oct?? Will I see 400whp with 100oct?
  2. bikerboy
    on the water looking for the sandbox
    no need for this "Big MAF" if you have this "Hydra ECM"
  3. FuJi K
    St. Paul, MN
    Thanks, Matt. ;)
  4. Musashi
    Female
    Clouds
    You may want to reinforce that body! :D
  5. readymix
    Eloh, El
    yeah, I would get to welding in some support for the car. You are talking about placing 400hp in a car that was designed with about 100hp in mind. You are going to shake apart at the seams.
  6. TSTRBOY2004
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Mushashi
    HIS or the CARS... cause I know he has a few screws loose.. ha ha ha
  7. FuJi K
    St. Paul, MN
    Russ!!!!
