Hitch Install.
Discussion in 'General Subaru Discussion' started by housemusic1, Mar 28, 2019.
  1. housemusic1
    housemusic1 Well-Known Member
    Any good recommendations for where I can have a hitch put on my Forester?
  2. sneefy
    sneefy Well-Known Member
    Your driveway. It's a piece of cake.
  3. housemusic1
    I was thinking about that, just not sure how confident I am about the wiring portion.
  4. sneefy
    You can always get an OEM harness. It's plug and play. The aftermarket ones, while cheaper, seem to involve splicing.
    A hitch (Draw-Tite or Curt) from etrailer is cheap and easy to install. I installed a Draw-Tite on my 2016. I did not install wiring, though, as I just use it for a bike rack.
  5. joebush44
    joebush44 Well-Known Member
    I'd recommend under the rear bumper of the vehicle - that's just my personal preference. ;)
  6. Krazylegz1485
    Under the front bumper is an oddly common alternative placement, too. Options!
  7. housemusic1
    I kinda walked right into that one, didn't I?
    Ntxhuav_Khang and tangledupinblu like this.
  8. sneefy
    For towing in reverse!
  9. pillboy
    Online
    Get two...volume discount.
  10. martinbrown981
    martinbrown981 New Member
    I would recommend you to install a hitch from any official services center, they take the full responsibility of installing we run a towing company and have a lot of towing trucks which we use for Blocked Driveway Removal in Queens, etc and we always install a hitch from the service center.
  11. JaloP
    JaloP Active Member
    What year is your Forester? I think most of the newer Subarus come with the end of the plug hidden behind the back seat on the driver's side. eTrailer has the other end for cheap, just plug it and rout it. (Not sure what years constitute "newer" but my '11 OB had that)
  12. housemusic1
    2015. Yes, they come with the plug on the driver's side rear panel, behind the back seat. The install video is pretty good too. Should be a fairly painfree install.
  13. Buddy
    Buddy Well-Known Member
    Where are you located? I just put a hitch on my 17FXT I'd be happy to give you a hand if you wanted to come to Farmington.
