How big is a STi stock turbo?
Discussion in 'Modifications And Maintenance' started by tux121, Apr 23, 2007.
  1. tux121
    tux121 Well-Known Member
    Champlin
    Anyone know?
  2. Justin
    Justin Well-Known Member
    St. Paul, MN
    what do you mean by "big"?
  3. shorty5198
    shorty5198 New Member
    some specs i found.
    Aspect ratio 18
    Turbine Impeller Dia ID 48mm/ OD 53mm, 11 blades
    Compressor Impeller Dia 46.48mm/60mm, 6+6 blades
    Wastegate port 25mm dia
    WG Port open 77.7 kPa @ 2mm, 89.9 @ 4mm
    twin scroll design. size is similar to the vf34.
  4. tux121
    Champlin
    as in 14g 16g 20g datadatada
  5. shorty5198
    i'd say a "small" 16g would be about the same as the vf39 power wise
  6. ShortytheFirefighter
    I'd be rechecking that "fact" Shorty. They are NOT a twin scroll. The VF36 and VF37 are twin scroll turbos, not the 39. The only Subarus that came with twin scrolls are the JDM V8 Spec C.
  7. WRX1
    Over there
    USDM sti is a vf39. the 16g will flow alot more air than the vf39 will. I will have to SEARCH for the turbo flow chart that I have posted before. IIRC the vf39 is around 400cfm and the snall 16g is around 500cfm.
  8. WRX1
    Over there
