how do you fix an alarm?
Discussion in 'Modifications And Maintenance' started by ProjectSTi, Jun 6, 2005.
  1. ProjectSTi
    ProjectSTi New Member
    somehow something is wrong with my 98 2.5RS alarm, it won't beep as loud as it did anymore, all you hear and see is the lights flashing to mean that it's locked or unlock
    has anyone ever had this problem? it's only a stock subaru alarm, battery seems fine, i'm not sure about the wireing...need some help
  2. Gspot
    Gspot New Member
    theres an option to turn the beep off and on. I believe its hold both buttons down for 3 seconds.
  3. Musashi
    You could try running a power source to the siren to see if its working. Than check the wire to see if its conducting properly.
  4. ProjectSTi
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Mushashi
    what do you mean by that? like using a digital multi meter?...i'll and Gspot i'll try that tomorrow
    before the alarm was working good, until one day i left the trunk open but then the trunk don't have a light so the car doesn't know that the trunk is open and it won't drain the battery, but then fromt hat day on the alarm will work after i park it over night, and after i drive it and park it, the alarm would be weak, it makes a sound of a duck, hahaha seriously, and then now all you hear/see is the lights flashing
  5. Musashi
    You could use any good meters or a test light. If thats the case you may want to double check the ground wire of your siren, and make a new one as needed. If the wiring is good you may want to add another siren just for an added security. ;)
  6. subi_2.5rs
    subi_2.5rs New Member
    like Mushashi said try the ground wire....
  7. ProjectSTi
    okay...thanks a lot guys i reallie appreciate it, this is my first car, and haha i just got it to breat again!!!...i uh fried the starter...
    but anywho will there be a meet up there on July 1st? i'll be coming up there to visit fuji cause we love each other that much...hahahaha j/k...anywho yeah i'd like to attend your meetings
