how much hp with 17 psi ?
Discussion in 'Modifications And Maintenance' started by baileyvang, Dec 17, 2015.
  1. baileyvang
    baileyvang Member
    i was wondering how much would you be getting within
    down pipe + exhausted within 17 psi ? how much hp you getting for 2004 wrx
  2. JasonoJordan
    This is not a question you can answer with your given information.
    tehfuzz likes this.
  3. Deathly
    Deathly Well-Known Member
  4. thomas franz
    No one can answer that question, but..... I have an aftermarket catless UP and DP with a turbo back exhaust running a cobb stage 2 93 octane tune. I hit 18 psi and my car put out like 215hp and 237 tq on the rs motors dyno.
  5. euro
    euro Well-Known Member
    100 hp
  6. tangledupinblu
    Don't listen to these chuckleheads.
    Stage 2 WRX at 17psi will be around 220-230whp.
    It will fluctuate because there are alot of little things that could make a difference one way or another.
    You would want:
    -uncatted up pipe
    -boost control solenoid (GrimmSpeed,GM,Cobb,etc)
    -turbo back exhaust
    -tune
    NAITOMEA_ST and Fastsuby like this.
  7. JasonoJordan
    But what if he is running e85 would be alot more then that...Still stand by my not enough information given to give an informed answer.
  8. tangledupinblu
    Yes. But off of the "stage 2" list that he did mention, that would be the ballpark.
    Fastsuby and Deathly like this.
  9. Nhibbs
    Nhibbs Well-Known Member
    Just tell people you have 500hp. On the internet my car has at least 2000hp.
  10. sneefy
    sneefy Well-Known Member
    At LEAST seventy-hundred bazillion horsepower. And so many gobs of torque you'd twist half of the chassis into another space-time continuum.
  11. project/driven
    I made 217 WHP at 17 PSI on my 2.0. TBE, STi top mount, 650 injectors, Shane@DB tuned
  12. tangledupinblu
    Sounds accurate for a dyno tune! The 220-230 would be more of a "road tune" set of numbers.
  13. Terry Ammerman
    Holy crap, just imagine the stories Ben could tell.
    Ryan FailRad likes this.
  14. Ryan FailRad
    That's almost 19 psi on e85 with fmic, short ram Intake and a turbo back exhaust in an 06 wrx (so it has the 2.5 instead of the 2.0 in your car)
  15. Cotts612
    Cotts612 Well-Known Member
    Dat torque tho! Awesome!
  16. tangledupinblu
    E85 and a 2.5L=t3htorques
    Ryan FailRad and Cotts612 like this.
  17. Nhibbs
    Silky21L, Ryan FailRad, BroCo and 2 others like this.
  18. retreif
    I am exhausted reading this.
    Ryan FailRad and BroCo like this.
  19. Ryan FailRad
    Also tuned by Nuke and he seems to tune get as much power as he can get as quick as possible and hold it as long as possible.
    Cotts612 likes this.
  20. Nhibbs
    I would say most/all tuners do this unless you specifically ask for a more linear tune for road racing or whatever where a peaky torque bomb upsets the balance of the car in corners.
    Otherwise pretty much all tuners go for max torque as soon as possible without compressor surging.
  21. NaMinesClarence
    NaMinesClarence Well-Known Member
    Lemme help! 2.0 fun!
    Downpipe, up pipe, spt catback, gmbcs 91 octane. Clutch went to poop on the dyno.
    2.0, downpipe, up pipe, catless, gmbcs, stock catback, e85
