How much oil?
Discussion in 'Modifications And Maintenance' started by project/driven, Nov 10, 2006.
  1. project/driven
    I gotta do my first oil change for my 02 WRX. How much oil are supposed to for a filter/oil change? btw where can I get a good shop manual for my car?
  2. AspitFire
    4.7 i think
  3. WRX1
    If you use the big filters, 5 quarts.
  4. Shibbs
    What kinds of oil/filters do people on here use, anyway?
  5. AspitFire
    mobile /Bosch...just switched from amsoil
  6. John16V
    John16V Well-Known Member
    OEM all the way
  7. John16V
    Define big filter which brand do you mean, Russ? OEM?
  8. COBBsoobyStage1
    COBBsoobyStage1 New Member
    I've run castrol syntec from day 1 - 5quarts. I use the performance filter too. Holds more oil but more oil will disipate heat better.
  9. John16V
    Hum..I heard that (in a RS) if you run OEM filter with 5 qt of oil is not good for your car.
  10. Shane86
    Shane86 Well-Known Member
    Mobil 1 oil 5W-30 in the winter, 10W-30 for summer
    Purolator pure 1 filter or mobil 1 filter... Napa Golds are pretty good too but not my preferred filter.
    a WRX/STI is a 4.5 qt fill of oil, so i just stop off at Wal-mart and pick up a 5qt jug of Mobil 1 full synthetic for $20
  11. WRX1
    Amsoil filters and oil. John, the dealership for a while had the stock wrx filters and the newer filters for the sti/legacy. The newer filters were pretty small compared to the wrx filters. The amsoil filters are larger than the stockers. When I dump in 5 quarts it is just a touch below the full mark.
  12. AspitFire
    the amsoil oil filters i used to use were small as heck. maybe i was using the wrong ones.
  13. wall of tvs
    I'm also an Amsoil fan. Now I just need to wait until 10k on both cars to switch back to it.
  14. WRX1
    Why 10k?? I started using amsoil at 2k in the wrx and 2.5k in the lgt. The motors are plenty broken in by time we get to them.
  15. wall of tvs
    I dunno. Just a random number, I guess, lol. I'll probably switch back to it when I get around to putting the stinkpipes back on in the rex.
  16. bikerwriter
    bikerwriter Well-Known Member
    And here I thought you would come to your senses and go with a catted DP. You'll replace that new car smell with the stink of gasoline. Every driver you pass will pull over, thinking their car is about to catch fire...
