how to fix a boost problem!!
Discussion in 'Modifications And Maintenance' started by ihaveawrx, Feb 9, 2007.
  1. ihaveawrx
    ihaveawrx New Member
    mtka beach
    i finaly fixed my boost problem after replacing all my boost lines and getting a new boost solenoid and checking every last problem, it was in valet mode! so if anyone ever only gets between 9 and 11 psi all the time then just turn the ignition so the battery is on only and then press the gas peddle down to the floor and then press the rear defrost button once. after that it should run fine. and just for the record, vishnu has awesome customer service! (you liars) :)
  2. Shibbs
    Butbutbut, mine only always gets between 9-11psi.....
  3. WRX1
    Over there
    So you have a ecutek reflash.
  4. wall of tvs
    dream ftw
    That's only if you have an ecutek reflash and 1 of the maps is a low boost map. It certainly won't work with any other type of EM (cobb, stock, otherwise).
  5. angusracer
    angusracer Well-Known Member
    haha... that's just room for improvement
  6. ihaveawrx
    mtka beach
    well it fixed my car so i'm happy
  7. carl
    we gotta gooooo
    woot!
