how to make carbon fiber?
Discussion in 'General Subaru Discussion' started by Battle Scar, Sep 16, 2005.
  1. Battle Scar
    Battle Scar New Member
    duluth
    is there like a dvd that talk about it? do u just buy the cloth and then put hardener and resin on it?
  2. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    Carbon fiber is a cloth that is layered in a form and then baked to cure. Procuring carbon fiber cloth is almost impossible, and it is extremely expensive. The baking time is measure in weeks.
    You can buy sheet stock if you want to make brackets and flat pieces. It can be cut and filed very easily. Just wear a respirator. The dust causes cancer. Quickly.
    Sorry.
  3. readymix
    Eloh, El
    Ok, I have never heard about baking it for weeks. It all depends on the resins you use. And CF cloth can be procured from all sorts of places on the internet. I have even seen rolls of it on eBay. There are plenty of tutorials on the net that can get you started. Look around. It isn't that hard to work with.
  4. AWDimprezaL
    Monticello.
    ^this guy knows hizz stuff, my freind re did his hull on his jetski with carbon fiber...you dont bake it, its all resin and sanding and curing, and cursing...it took him 2 years to finish it
  5. tbone
    tbone Well-Known Member
    MN
    I have seen materials books at B&N bookstore. Look for Automotive DIY section, they may have them
  6. AspitFire
    MN
    I think when he is talking about baking the carbon fiber, he is reffering to when the actual pieces are made(turning it into raw material), not when you are molding them to your applications.
  7. Battle Scar
    duluth
    ok thanks for all the info guys :D so do the cf cloth have different quarity?
  8. readymix
    Eloh, El
    Yes, there are different weaves, different widths for the "threads."
    Find a book on it, or look on Google. I am sure there is aplace that identifies and lists what each type is for.
  9. bikerwriter
    St. Louis Park
    Just curious, but what are you trying to make, Battle Scar?
  10. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    that ready mix is so smart! he can do it all
  11. Battle Scar
    duluth
    i have no clue, i just wanna learn. i just order a lil sheet from ebay, maybe i make me a pair of side mirror covers as tester.
  12. readymix
    Eloh, El
    My suggestion to learning would be to make boxes. Or flat sheets. THen move up in complexity from there. Getting the basics down helps alot. It is cool you just wanna dive right in, but I recommend getting some small cardboard boxes and try using those as practice pieces. Mold yourself a few CF boxes or sodacan sleeves or whatever, then move up in complexity.
  13. bluebaru06
    bluebaru06 New Member
    Drivin my scoob thru your house
    CF is used and worked just like fiberglass. You use an epoxy resin to set the CF "cloth" on or in a mold. Radymix's recomendation of a sodacan cover is a really good one. That way you can get used to how the CF cloth molds and how fast the resins set up. Good luck and have fun.
  14. wrxpeed
    wrxpeed CobraPeed
    Maple Grove
    i'm pretty sure the baking is referring to the actual baking of the cotton threads. Yes, carbon fiber is actually cotton strands that are baked at extremely high temps, then when its all said and done the final product is the strands of carbon left that is then weaved and held together in shape with a resin that then cures. there was a huge article about it like 3 years ago in some Spo-Com mag, i can't beleive i remember that much.
  15. r32657
    r32657 Well-Known Member
    If you want to make it aerospace grade, than you will need to bake/cure it. Make the carbon and resin mix in a vacuum, so the air bubbles are very small or non-existing. The type of carbon fiber is important as well, is it short cut or long cut. If you just looking at making things for the bling factor, but not mission critical/load bearing, you can just get away with overlaying it on something like fiberglass, or whatever. Slap on some cheap resin and voila! EBay hood scoops. I watched how the aerospace grade stuff was made a long time ago at NWA.
  16. Substeroo
    Substeroo Well-Known Member
  17. r32657
    some other good places to check out, would be some parts/frame makers in the bike industry. I remember when the cold war ended and MTB's started to take off, a lot of military manufacturers turned to making those for a while.
