hta68 342hp 300tq 02 WRX
Discussion in 'Modifications And Maintenance' started by blake, Jan 12, 2010.
  1. blake
    blake Well-Known Member
    E85
    ej207 short block:
    JE pistons
    Eagle Rods
    crank drilled
    balanced
    nitride coated crank
    ej205 heads with BC:
    Valves +1mm over
    Springs
    Retainers
    272 Cams
    apexi avcr, APS 525 fmic, Borla hush catback, walbro 255, 1000cc DW, Perrin fuel rails, perrin big maf, tgv delets, 38mm ewg, invidia dp, more.
    Figured I'd post some results. This is the highest I can get out of the hta68 on DB's dyno. Thanks to Nuke and TDagen for checking it out over on Nasioc, giving me input throughout the issues. Still trying to diagnose what is going on with losing power. It seems to be narrowed down to just to small of a hotside. Hopefully that's the issue. Open to thoughts.
  2. piddster
    That's one hell of a peak number. I hope you can figure out the tail-off at the end.
  3. Nuke
    Orly ;)
  4. Kevin
    Kevin Well-Known Member
    surprised you are not seeing higher tourque numbers running E85...
    nice peak number tho!
  5. AWDimprezaL
    Well, it IS a 2.0 ;)
  6. Squiggly
    Squiggly Squiggly
    stock header and up pipe?
  7. Kevin
    this is true.... lol
  8. blake
    Grimmspeed header with highflow cat and uppipe.
    I think tq is low since it's a 2.0 and the cams. I think the cams just kill tq, but that's just a guess. I'm sure people that have more experience with them can chime in.
  9. yamie700
    yamie700 Well-Known Member
    Wow, so you're running 27-28psi right to redline? Is the hta68 still efficient at that level or is it a flamethrower?
  10. Bullwinkle
    Well, take a look at torque fall of dramatically after about 6600. I like the high redline, but you're not really seeing good power that high.
    Anyway, very nice setup, regardless. E85 is a beast :)
  11. blake
    I'm going with flamethrower on this one. FP lists it being effecient up from 17-25 psi.
    Thanks bullwinkle. It is fun up to 6600, that's for sure. This is just proof I need to go bigger!
  12. piddster
    I'm just wondering why your setup falls on it's face and MAP's did not. What am I missing here?
  13. blake
    Rpm is one, he's wasn't going to 8k (I think he is still on stock engine and heads). To go with that, no headwork. I just don't think this turbo can push enough air for my setup. Well, that's what I hope at least.
  14. goodhart
    goodhart Well-Known Member
    I wouldn't be so sure about that, Evo III 16Gs are even less efficient, and there are plenty of people running 30+ lbs/boost on those. On other engines 272's help high end, while hurting torque and low end.
    I wonder if the curve looks so different compared to the other car running the 68hta because of a Dyno Dynamics being a load type dyno and the dynojet not being able to load?
    These are great numbers though!!
  15. 03subyR
    03subyR Well-Known Member
    Nice numbers, I should convert to E85 after seeing this results :yumyum:. Too bad I have to drive it in the winter too.
  16. MCXL
    MCXL Well-Known Member
    Why is this a problem for you? E85 becomes E70 in winter (to help fight the cold). I'm running that and its going great so far.
  17. goodhart
    Many people experience hard starting in the cold weather, especially if the car is parked outside regularly.
  18. 03subyR
    Plus tune needs to be adjusted for winter E85 fuel vs. summer.
  19. piddster
    If you're anal, the tune should be adjusted every tank of fuel when running corn.
  20. zisson33
    zisson33 Well-Known Member
    This may be a dumb question, but tune at the beginning of the tank? Is there that much variance?:???: Do folks do that? I'm thinking that's a little too much for me...
  21. subezero
    subezero Active Member
    Sick..from Mankato? My folks live there, might have to check that behemoth out next time I'm down there.
  22. Nuke
    You can if you want to, but it isn't needed unless the tank is really, REALLY throwing your car off.
  23. blake
    Word. Hit me up next time your I town.
