I am broke part 3 ??
Discussion in 'Off-Topic' started by John16V, Jul 29, 2004.
  1. John16V
    John16V Well-Known Member
    Last night I was infrom that one of my brake light was out..I am like "ok, no problem probaly a bad bulb".
    Replace with a new bulb...no good..."ok, fuse?" replace new fuse..still no good [xx(]
    Anyway, want to take a crack at this?? before I bring bring this POS
    to the stealership again?! please help, I will definitely be broke if I take this car in.... :(
  2. jprice
    jprice Well-Known Member
    Hastings, MN
    John,
    I congratulate you for asking here first before taking it to the stealership!
  3. John16V
    Is not like I have choice anymore...:(! I just wanted to save much as I can for the new car.....
  4. WRX1
    Over there
    First I would pull the bulb and check the wies for voltage and/or a short. If you want, I can help ya with that. It should only take 10-15 min to do that.
  5. John16V
    Thx, Russ...I'll buy lunch just tell me when you avavible (I am out this Friday and Saturday) I am open this Sunday, if not next week is
    cool too.
  6. igofast
    igofast New Member
    St. Cloud, MN
    Start tracing back. Is it just the brake light, or are the running lights also out? How about the turn signals?
    Check to see if the bulb is getting power by using a multimeter or other means. If it's not getting power there, then check for power at the fuse. Then go from there.
  7. Yang
    Yang Well-Known Member
    mpls
    JOHN;
    [yia]SHAKES HIS HEAD[/yia]
    I am telling you it's that girl! Why are you so blind. EEeerr......
    But yea, i bet a few guys here knows whats really wrong.
  8. John16V
    John, everything works around there, turns, running light are all fine..check power at fuse? Ok, soon as I get my hand a volt meter.
    thx
  9. John16V
    Yia, I was no where near that girl....
  10. Yang
    mpls
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by John16V
    :eek:, in that case Check your fuses under the steering wheel(its like a little opening storage compartment next to the steering wheel, to your left). You dont need a volt meter. Find the white tweezer in the cover under the main fuse box(near your washer fluid under the hood). Use that tweezer and check the rear lights fuse (they should tell you "which one" on the back of the cover of the compartment door). If it is split in half, replace it cause its blown. They usually have some spare ones under the cover of the main fuse box(where you got the tweezer from).
    See if this works Jonny Appleseed:D. I had the same Prob when I install those JDM tail lights cause they are too cool:cool:....
  11. igofast
    igofast New Member
    St. Cloud, MN
    thx
    Let Russ(or someone else) help you out since he has one and knows how to use it.
  12. WRX1
    Over there
    Are both side out or just one?? I have Sunday open, give me a call.
  13. John16V
    Russ, just one side (passager side) :???: what time are you good on Sunday? I am open most of the day...let me know the best time for you
    thx again...
