i got free tires!!!!!!
Discussion in 'Off-Topic' started by wagonL, Nov 24, 2005.
  1. wagonL
    wagonL Well-Known Member
    well...yesterday..one of my work buddies called and see if i knew anyone wants some pretty fresh 205/70r14...all four...for free...im like....i do!...so..today...i just picked them up...still in very good condition and best of all...they're all free...man...just when i need tires....and ...does anyone know if they would fit my donuts without a problem? my stocks are 185/65r14....im thinking it should fit...without a problem...right? well..let me know...and but yea...if they dont...someone else can take them...
    wagonL
  2. Todd
    Todd The Originator Staff Member
    I've put larger on a Loyale Wagon... ;)
  3. kickin_81
    kickin_81 Well-Known Member
    Both a taller and a wider tire!?!?! Check for tire clearance between the struts and the fender. The rears are more likely to rub than the fronts.
  4. prezawagon
    prezawagon Well-Known Member
    I'm running 185/70r14 on my car right now, TONS of clearance even with the lower springs. 205/70r14 is quite a bit bigger though, the width should be fine, but it's a lot taller, even bigger than 205/55r16.
    Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
    185/65-14 4.7in 11.7in 23.5in 73.7in 859 0.0%
    185/70-14 5.1in 12.1in 24.2in 76.0in 834 3.1%
    205/55-16 4.4in 12.4in 24.9in 78.2in 811 6.0%
    205/70-14 5.6in 12.6in 25.3in 79.5in 797 7.8%
