I HATE phillips/flathead screws!!!!
Discussion in 'Modifications And Maintenance' started by Paul Revere, Apr 16, 2008.
  1. Paul Revere
    Why can't the world be all metric and either bolts, nuts, or allen head screws!!
    So I need to take apart my 7 year old carburetor on my dirt bike and the screws will not budge, yes I sprayed penetrating fluid on them and now I wait. It will either come apart or I'm gonna have to half ass it and use sea-foam.
    I left gas in my carb from August will sea-foam clean the carb or do I need to take it apart?
  2. Iroc-Z
    Iroc-Z Well-Known Member
    If you have it on a bench you can use an impact screwdriver.
  3. Gridlocked
    reverse drill bits FTW
  4. readymix
    Yes, impact screw driver FTW.
  5. w_o_t_boy
    w_o_t_boy Well-Known Member
    I grabbed the screw head with vice grips and that plus the screwdriver got my carbs apart a while ago. Getting an impact screwdriver would be smarter, though. You don't want to strip those out.
  6. wall of tvs
    Yup, I had to use a vice grips on both of my YZs when working on their carbs. I immediately then went to Home Depot and bought a bunch of allen head bolts to replace them.
    Brilliant part on Yamaha/Mikuni's behalf to use super soft brass screws on their carbs (both on the float bowl & slide cap). :roll:
  7. Paul Revere
    How does this vise grip method work?
  8. wall of tvs
    Put the vice grip on the head of the screw and turn. lol.
  9. Paul Revere
    Damn Tom that seems like some voodoo ****, I'll try that when I get off work.
  10. bikerwriter
    bikerwriter Well-Known Member
    Impact screwdriver, followed by vice-grips, followed by...Oven cleaner!!!
    It's what the shops use on carbs to clean the passages. Caution, may eat all plastics you do not remove.
  11. flstffxe
    flstffxe Well-Known Member
    some oven cleaner will also eat aluminum and brass too. It can etch the passage ways and screw up the flow of fuel(makes it a pain to tune), I have seen it turn a simple $50 carb job into a $450 nightmare. Just a FYI.
  12. Paul Revere
    ^Didn't plan on going that route but thanks for the heads up
  13. Ej22TIM
    Ej22TIM Well-Known Member
    the impact screwdriver has to be the simplest and best invention for stripped screws.
    the vice grip method will work, but I wouldnt reccomend it.
  14. wrexinator03
    wrexinator03 Banana Cream
    if not you can always use an easy-out
  15. Paul Revere
    Thanks guys I'm going to try the vise-grip first with the thought of buying allen head bolts for next time, although after reading about the impact screw driver I'm gonna need on of those.
  16. Ej22TIM
    I have one you can borrow.
  17. metalmaster
    metalmaster New Member
    I have found that if you insert philips head screwdriver into screw and smack it with a hammer it tends to break the threads free. also if you can file the head of the screw flat on two opposing sides you get a better surface for a wrench or vice grips.
  18. flstffxe
    Replacing the screws with allens is the way to go. I do it every time I do a carb/s on a bike, been doing it for years and it saves you time the next time you need to get into them.
  19. SubieDave
    SubieDave Well-Known Member
    beep beep :wavey:
