I have a question about idle boost
Discussion in 'Modifications And Maintenance' started by kickin_81, Jan 28, 2004.
  1. kickin_81
    kickin_81 Well-Known Member
    I've driven everywhere with my car. The VF30 turbo spools fine and hard to redline at 16-17 psi. My concern is that when I'm at idle and I rev up the motor, I don't build any boost. My boost gauge will not read above ~0 psi (+/- 2psi). I've seen some WRX cars that can rev their motor and have the BOV release air when they let off the gas. I've tried to rev it to redline once and still the boost gauge will not go past 2 psi nor will my BOV release boost pressure. The ECU has had an EcuTek reflashed from Vishnu on 91 octane. Is this normal, is this abnormal, or does anyone think the reflash could have done this to keep the motor in safe mode for such conditions boost is unnecessary? :???:
  2. jprice
    jprice Well-Known Member
    Hmm... sounds like you want to give people the vroooomPPPPSSHHHHH!!! at the stoplights. :-p
    My car doesn't build any boost without a load that needs it...with stock or modified programming. The turbo car I have isn't a subie, but thought I'd throw in my 2 cents anyhow.
  3. RallyNavvie
    RallyNavvie Well-Known Member
    If you were able to get boost at idle I think you would be doing your car wrong.
  4. Zola
    Zola Well-Known Member
    Unless you have a different transmission than I think you do, I wouldn't want to launch with boost...you'd probably vaporize first gear. :eek:
  5. kickin_81
    Well, revving my car to cars at stoplights doesn't happen often, but it'd be fun. :D I'd rather have them think my car is slow and then see their reaction when I overpower them. I just had a feeling that not building boost with no load could not be normal, because I thought that boost builds as RPMs goes up. I'm a newb to turbos. :I
  6. kickin_81
    Off Topic: I think the shorter gearing RS transmission can handle power just as well as the WRX tranny. It takes less power to rotate a short gear than a longer one, right? I calculated 61 mph in second gear at 7000 rpm. Is that close to a WRX's gearing?
  7. RallyNavvie
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by kickin_81
    Off Topic: I think the shorter gearing RS transmission can handle power just as well as the WRX tranny<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
    Whoa... Try that and let us know how it goes
  8. kickin_81
    *knocks on wood* I would never want to experience shredded teeth. Wouldn't you believe that the RS-T's that strip their gears are due to the tremendous torque the motors produce in the low RPM's? ...all else being equal. Our tranny's are built for torque, but sadly not turbos.
    Back to the subject, thanks for the response guys! I didn't know Subarus had this feature to fight against tranny damage. Besides, boosting the motor without proper airflow through the intercooler will cause detonation, wouldn't it?
  9. WRX1
    It will take some time before the air temps get hot enough to cause det. I only generated 16-18psi of boost to launch.}:)
