I need a better opinion...
Discussion in 'Modifications And Maintenance' started by sapalas, Oct 12, 2007.
  1. sapalas
    sapalas Well-Known Member
    Is there anyone around today that would be willing to take a look at my car, I am located in Shakopee, but I will drive to where ever you are located.
    I have a loud wheeeeeee!!! sound coming from the front passenger side wheel, I am not sure if it is just something to do with my brakes or if it is a wheel bearing going out. I don't have a jack or anything to raise my car and i have never dealt with a wheel bearing before. So I don't know what i should be looking for anyway.
    If you would be willing to take a look either shoot me a PM or give me a call.
    Thanks Guys,
    Shaun
    952-240-1872
  2. Justin
    Justin Well-Known Member
    easiest thing would be to first make sure there are no exhaust leaks that are making noises. is this a possibility?
  3. PRA4SNO
    PRA4SNO Well-Known Member
    rock stuck in your brake sheild?
  4. AWDimprezaL
    weeeeeeeee means you are probably on the "squeelers" time for pads.
  5. Justin
    i'm trying to visualize what "weeeee" sounds like but cant
  6. stoooo
    stoooo Well-Known Member
    Had that happen before, but that's more of a squeeeeeeeeeeeee kind of noise, like nails on a blackboard. Quick fix for it is to reverse up to about 20mph and stomp on the brakes. The rock should fly out of the gap in the shield.
    Stuart.
  7. Aegis
    this is all i can come up with
  8. sapalas
    It happens consistently when i turn left hard enough to really put wieght on that wheel, and usually does it when i go in reverse but not nearly as loud.
  9. AWDimprezaL
    Its def pads
  10. wall of tvs
    I think your car hates you, Shaun.
  11. sapalas
    ^fixed that for you
    I know, I guess when it rains it pours.
  12. TSTRBOY2004
    Shaun if you wanna drive to Jordan I can take a look sometime tomorrow.... I will be -around my house most the day... 952-224-6353
  13. Dynapar
    could be the heat shield somehow got bent and it rubbing on the rotor. this happens to me frequently. annoying but not hamrful
  14. tmarc12366009
    Hmmm... What kind of car? WRX? How many miles?
    If so it sounds like brake pad wear indicator... I had the same issue with mine at around 60,000 miles. Sound would be noticed when turning left and it came from the front passenger side...
    Nathan took a look at it as I thought it was a bearing possibly, but nope just worn out break pads was all... We cut the indicator down to make the sound go away until I got my new breaks. No more noise! ;)
    Just a thought as it appears to be a similar situation...
    -Marc
