I need help with...
Discussion in 'Off-Topic' started by k_thaosta, Sep 11, 2006.
  1. k_thaosta
    k_thaosta Well-Known Member
    I need help with my wife's Golf... makes a grinding noise while driving and turns... I'm thinking it's the bearings on the hubs but does anyone have an online manual or can direct me for help on this? Any help would be appreciated... Thanks
  2. Squiggly
    Squiggly Squiggly
    check the tie rods
  3. TSTRBOY2004
    tie rods would clunk not grind unless they are rubbing on something else metal and moving... could be bearing.. could be backing shield.... get under there and look... se ehwat you can find... if not take it by a shop..most shops will do a free front end inspection..
  4. k_thaosta
    I've set this thing on stands and looked underneath and can see nothing wrong... I will take it to a shop... any suggestions for shop? This needs a fix ASAP...
  5. Musashi
    Why not take it to WRXBOY2003's shop, he does an awsome job.
  6. tbone
    tbone Well-Known Member
    call bp morries subaru and ask for brett in parts dept. he's a vw guy knows a lot of shizzle....he might help you
