I Really Want To Try Thiis
Discussion in 'Off-Topic' started by Se7enrex, Nov 27, 2007.
  1. Se7enrex
    Se7enrex Well-Known Member
  2. Korsch_RS
    Korsch_RS New Member
    hmmm, kinda sounds a little fishy. I would think that you would lose a ton of energy by splitting the two H-O bonds.
    I think a more viable solution would be a new 6-stroke engine that some old guy built. I read the article in Popular Science a while ago, in some special edition about modern Inventors and their Inventions. One of the guys was IIRC a mechanical engineer and figured out this way to use water for adding another power stroke to a standard 4-stroke engine, turning it into a 6-stroke engine with 2 power strokes, as opposed to a 4-stroke with 1 power stroke.
    here's how it worked:
    1. Engine goes through standard 4-stroke cycle, suck squish bang blow, then it get's interesting.
    2. between the fourth and the fifth stroke, water is injected into the combustion chamber, hit the superhot piston, and instantly vaporize
    3. the now steam in the C. Chamber, creates a ton of pressure, and pushes piston down. thus stroke #5, power stroke #2
    4. Piston reaches Bottom Dead Center, another valve opens in the head, and the piston pushes the steam out of the valve (separate from the standard intake and exhaust valves), the steam is condensed, and sent to a reservoir to be re injected later.
    So, the strokes are:
    1. Intake
    2. Compression
    3. Expansion, Gasoline Power Stroke
    4. Exhaust
    5. Water Injection, Steam Power Stroke
    6. Steam Exhaust
  3. speedyham
    speedyham Well-Known Member
    No- will not work. Ever.
    You have lost all respect I might have ever had for you by posting it as a serious idea for consideration.
  4. fobiawrx
    fobiawrx Fabiola
    i also want to "port" my turbo using sand.....
  5. AWDimprezaL
    i want to plumb my exhaust into my intake, but i dont think my chassis can handle the power
  6. hofit
    hofit Well-Known Member
    I'm sure it works. I believe it cause I read it on the internet.
  7. w_o_t_boy
    w_o_t_boy Well-Known Member
    I have a perpetual motion machine I'll sell you cheap.
  8. w_o_t_boy
    I'm pretty sure injecting oxygen into a normal internal combustion engine is a bad idea. This is one of many things wrong with this totally retarded plan. The other is a little thing called CONSERVATION OF ENERGY
  9. Scooby02
    Scooby02 Well-Known Member
    my car has a turbo.
    Oh and if I pee on the electric horse fence will it hurt?
  10. blackozone
    How much please?
  11. tangledupinblu
    Online
    Only if you're sober.
