I think I blew my engine :(
Discussion in 'Modifications And Maintenance' started by powerlabs, Feb 20, 2006.
  1. powerlabs
    powerlabs New Member
    OK, not quite blew it, but there is something seriously wrong with it; I had the up pipe off for porting and polishing, then I drove to the car wash and powerwashed the block (can't imagine this being bad, but I figured I'd throw it in just to make sure). I checked the oil level and started driving to Milwaukee. It was -20F and the roads were bad, so I went WOT maybe 5 times. When I did this, boost hit 22PSI (highest it has ever been) twice. I had race gas on, so there was NO knock. Power was awe-inspiring. I had to worry about spinning tires in 5th.
    200 miles into the trip I stop at a stop light and the oil light flashes briefly; the car was down on oil by 4 Quarts! (I checked the oil immediatelly before I left).
    I top it off and drive another 130 miles. Now the car is down by maybe 2 - 3 quarts and there is a chocolate milk consistency substance sprayed all over the inside of my engine bay (dipstick popped out). I'm guessing that substance is oil mixed with coolant.
    Aside from that the engine runs perfectly fine and idles as normal. Compression is around 140 on 1 2 3 and 128 on Cylinder #4. The car is down in Milwaukee and I'm not sure what to do now.
    Any ideas?
  2. 95lwrx
    95lwrx Well-Known Member
    how are the spark plugs, were any of them covered in coolant or oil or a mix?
  3. JiDM_WeRX
    JiDM_WeRX Well-Known Member
    head gasket
  4. 95lwrx
    he already stated elsewhere that's what he thought but that doesn't explain the massive oil consumption, at least i don't think just a head gasket would do that, but i'll let others with more experience chime in too
  5. AWDimprezaL
    it could be blown all the way through the water portion of the head gasket, to the oil ports
  6. 83projectbrat
    83projectbrat New Member
    well i guess you wil just have to sell that car to me.... :(
  7. joegengsta
    joegengsta BANNED
    oh, sorry to hear that. i've been there before man
  8. RallyNavvie
    RallyNavvie Well-Known Member
    Wow, were the unicorns having a hard time keeping up then? :lol:
    I can only imagine what sort of wierd things pressure-washing an engine bay could do. You could be forcing dirt and grime deeper into things or washing away lubricants. Then to take it out in severe cold is just asking for that water to freeze and crack things. Run a leakdown if you can. There are also those kits that can test your coolant for exhaust/oil from a leak. That should narrow it down to head gaskets or not. Did you check the rest of the oil system for loose fittings, like the return line and such?
    Glad I got rid of my car before the head gaskets got bad :(
  9. RichWRX
    RichWRX Well-Known Member
    sorry to hear about your car, hopefully its nothing too bad
  10. AspitFire
    lol :lol:
  11. powerlabs
    :roll:
    I don't think you are supposed to have lubricants OUTSIDE your engine, and if a 5000PSI turbocharged combustion event isn't blowing stuff out of the engine, a little jet of water sure as hell isn't going to blow stuff in.
    I checked and double checked everything before I went out... Plus I didn't mess with any oil or coolant lines, so I don't think its an external leak... I'm looking at all possibilities though; tomorrow hopefully I'll have a leakdown test done.
  12. WRX1
    Well, you pumped out 6-7 quarts of oil in 330 miles, so something has to be wet. All that oil needs to go someplace. What does the dipstick look like (ie is there coolant and oil on it)?
  13. AWDimprezaL
    dipstick popped out?????? plugged PVC!!!!!!!!!!!
  14. powerlabs
    The dipstick looks like a chocolate milk popsicle :(
    Plugged PCV? Good call. I'll look into that.
  15. 02blubru
    What does the PCV stand for and do?
  16. AWDimprezaL
    positive crank-case ventilation, vents the inside of the engine, if its plugged it will start sucking oil and crud through the intake manifold
  17. WRX1
    are you low on anti-freeze? Kinda sounds like a head gasket.
  18. powerlabs
    Level dropped by an inch, if that.
  19. Shane
    Shane New Member
    Is your exhaust full chocolate of milk goop? Did you drain the oil yet? Chocolate milk is from oil and coolant mixing. The most common causes would be a blown headgasket, cracked cylinder wall or a water cooled turbo with a cracked center section.
  20. TSTRBOY2004
    positive crankcase ventilation... allows pressure to breath so dipstick dont pop.. among other things
  21. Dynapar
    some thing control valce.
    anyway, i would have to guess either that the power washer ruptured a hose, or else the water froze somewhere and causes a crack. i know this doesnt help at all, but i am trying to add to the thought process.
    could it be a seal by the oil/water pump? i dont recall if the two pumps line up exactly next to each other, but maybe the seal gave and is allowing the fluids to mix.
