I'm a smoker
Discussion in 'Modifications And Maintenance' started by B1Bone, Jul 21, 2006.
  1. B1Bone
    B1Bone BANNED
    Recently (beginning after I was almost out of oil and put in 5 bottles), everytime I start my car a plume of light smoke comes out of the exhaust of my 04 sti. The only mod I have is a bov ( a fully recirculating one)
    What could it be?
    I've also noticed since, that my gas mileage has gone down slightly.
  2. Scuba Steve
    I assume this is blue smoke, not white smoke? How many miles? under warranty? Compression test might be a good idea?
  3. B1Bone
    B1Bone BANNED
    Yeah, it's definately not white smoke, more of a blue I guess.
    Yes, the car is under warranty. 2004 with 36,xxx miles.
  4. Dynapar
    headgasket? turbo gaskets?
  5. Scuba Steve
    i would recommend throwing the stock bov back on and take it to the dealer. I've heard there's been issues with the #2 cylinder with the 2.5....
    However, I could be totally wrong on the #2 cylinder, there's a # of things that could be wrong including oil lines to the turbo, etc...
    i would say poke around, but if it's under warranty have SOA deal with it.
    do not take it to the dealer with an aftermarket bov of any kind.
    good luck!!!!
  6. B1Bone
    B1Bone BANNED
    alright sounds like a plan. Could putting in a crap load of new oil have anything to do with it?
  7. Scuba Steve
    No, unless you read the dip stick wrong and put a few extra quarts in by mistake. But you had the smoke before you even added oil, if I'm not mistaken.
  8. B1Bone
    B1Bone BANNED
    No, the dipstick was below the E line :hsugh: , and IIRC it can take around 5.5 quarts of oil, so I threw in 5 quarts.
    I did not have the smoke before I added the oil to my knowledge. The adding of the oil is the only thing I can think of that I have done recently. Meaning I havent dragged or pushed the car or anything recently.
  9. rskm1
    rskm1 Well-Known Member
    Ummmmmm, I could be wrong, but doesn't the "low mark" on most dipsticks represent "add 1 quart"?
    I'm pretty sure it doesn't mean "Empty"!
    So how high up on the dipstick did the oil reach AFTER you'd added 5 more quarts??
  10. WRX1
    ^^^^ Thats my question. Usually the low line is add 1 quart, and *MAYBE* go as far as adding 2 quarts if it doesn't read on the dipstick at all. You should always only add 1 quart at a time and take a new dipstick reading. My quesss is that it is WAY over full and you are getting some oil past the rings and such. That is a very dangerous condition also.
  11. Radial GT
    Radial GT New Member
    If you add too much oil it will be blowing past your valve seals and oil seals. Not to mention air-ating a whole lot. If it didn't smoke before you added oil, I'd say you added WAY too much.
    How did you look loose 5 qts of oil anyway? A car with that many miles shouldn't be using any. It your loosing 5 qts between changes, your either leaking a hellish amount, or burning it. And you would notice both. Between parking and driving you would somewhere along the way notice 5 qts of oil.
    Also if you check your engine when it is hot, you get a false reading.
  12. badbennyb
    I agree it sounds like maybe too much oil added. I would start checking your oil a little more regularly. I just do mine evertime I get gas or if i'm spending a little time cleaning up the car.
  13. B1Bone
    B1Bone BANNED
    So, what you're saying is that I need to either let out some oil or find one of those oil pumps?:laugh:
  14. Dynapar
    well, to much oil can cuase all your seals to go bad (thus lotsa smoke). as far as i have heard it better to run low on oil then with too much.
  15. B1Bone
    B1Bone BANNED
    I assume a dealer or jiffy would have an oil extractor, no?
  16. AWDimprezaL
    extractor? are you that cheap? no, just get your oil changed again!, its probably already shot anyways from all the foaming that it was doing when wrapping around the crank under any RPM.
  17. TSTRBOY2004
    hmmmmm $50 extractor tool or $30 oil change..... ummmm lets see
  18. Sogonerg
    Sogonerg Anteater
    I hope your seals are still good...After the oil change...
  19. AWDimprezaL
    im gonna add.... how do you people keep running your cars out of oil!
  20. B1Bone
    B1Bone BANNED
    cuz I have a turbo the size of a pumpkin
  21. TSTRBOY2004
    then wouldnt it make sense to be more pro-active in watching those sorts of things....???
  22. FuJi K
    I WAS going to do my oil change......hehehehe
    if you just changed your oil, then have Jiffylube do a "1 or 2-count" on draining some oil. OR simply do your own oil change like most of us do.
  23. piddster
    You added 5 quarts??!!!!?!?!?!!?!?!?!?
    Most subaru's take 4.6 quarts. I'll agree with everyone else that you are probably way overfull. Just drain a bit and top it off to the correct level. Sounds to me a thorough review of the owners manual is in order.
  24. Scuba Steve
    any updates?
