I'll be installing new coilovers and sway bars this Saturday and I was wondering if anyone had an air or corded impact driver that I could borrow? You are welcome to join and help out. There will be beer.
When I did struts on my 05 STI there was really no room to even use an impact. I mainly used a breaker bar.
I plan on using it mainly for the lugs. Rather than sitting there and doing them by hand the entire way on and off. Just to make it a bit quicker and easier. Any chance I could pick them up tonight or tomorrow?
I work in WBL and can run around to wherever tomorrow afternoon/evening. If I don't hear back from @JasonoJordan I'll run up and meet you wherever.
Just to be clear, an impact driver is for screws, like the ones that hold on rotors. Impact wrench is the gun. I have a 1/2 inch Husky air impact wrench that is all yours if you want. Im in Brooklyn Park and will be available all weekend.
Terminology, really. I'd say a driver is more low torque, higher speed, with the emphasis on spinning (driving a screw). An impact has way more emphasis on torque rather than speed, like taking lug nuts or stuck bolts off. Just my opinion.
Sounds like I want a driver for what I'll be doing. If the driver can't take it off, I'll have a breaker bar to get it loose then use the driver to just quickly take it off and put it back on while tightening everything with a torque wrench to spec.
If all you're looking for is something to put them on and take them off rapidly without getting them tight, I'd say go for it. You can get socket adapters for them. I'd definitely break them loose with the breaker bar first, tho.
Well your in luck I have one of each you will be borrowing. So your good to go. I have the 3/8" adapter already in the driver.
Fwiw, I doubt these tools are going to save you enough time to be worth running around town to pick them up and return them.
Ugga duggas make you feel like a real mechanic, however. Plus impact tools give you the opportunity to eff up your wheels faster when the socket slips off the lug nut.
Impact driver, as in screwdriver, is for screws. Impact wrench, as in a wrench, is for nuts and bolts. Here’s a link to see what an impact drive looks like. You put it on a screw head and hit it with a hammer and it turns the screw at the same time. Not used for nuts and bolts. However, I’m with these other guys and thinking t would just be quicker to use hand tools. I’ve got air tools in my garage but usually end up using mostly hand tools anyway. Definitely get a better feel for how tight you’re making things. https://www.google.com/url?sa=i&sou...aw1hJWIVmQxEREOWleY5g1KE&ust=1529928363393100
Actually, you can use the “screw impact” that you’re referring to as an impact for nuts and bolts as well. So you’re half right. I use my “screw impact” to remove lugs with one of these... https://www.homedepot.com/p/DEWALT-3-8-in-Socket-Adapter-DW2542/100495100
I think the vast majority of people would refer to these tools as an impact driver before the handheld, hammer style one. Maybe it's just a more modern term? Googling "impact driver" brings up all the cordless ones first.
I think most of the good ones probably do, although I'd say you're most likely at the upper limits of them. Maybe good in a pinch but they make cordless impact wrenches for a reason.
Either way it's defined, its all semantics. Minnesotanice what did you end up doing for your project and how did it turn out?
No doubt! Was just stating that you can use the impact drill for nuts and bolts. We drive big lag bolts all the time when setting ledger boards for decks at work. Most of them will drive about 150-200 5 or 6 inch lag bolts with one battery charge! But i agree mostly with your definition of “impact drill” and “impact wrench”. A battery operated impact wrench will handle almost any car job that you are working on.
Hey everyone, didn't have a chance to check in this weekend. Everything went on fine and feels great! The impact wrench was definitely needed on a few bolts on the underbody as them bitches were on there. A little liquid wrench and power got the job done. Yes, the job could have been done without them but its nice to have some extra power here and there if you get tired of cranking while laying on the ground. I used the impacts more for sway bar work than the coilovers. All is good now though!
Love mine as well, just gotta keep making sure it stays hidden so the wife doesn't keep trying to use it to drill holes in the wall.
