Impreza - Jetta
Discussion in 'General Subaru Discussion' started by Mronningen37, Aug 7, 2015.
  1. Mronningen37
    Mronningen37 Member
    Do the subaru and vw bolt patterns match up?
  2. silver03
    I would say yes, there are VW's with the 5x100 bolt pattern....but offset can be a deal killer.
  3. Mronningen37
    Mronningen37 Member
    How would I be able to tell?
  4. Shabbaru
    Shabbaru Active Member
    The year of the car the wheels came off of.
  5. pillboy
    Center bore could be an issue too.
  6. xveganxcowboyx
    It looks like VW uses a 57.1mm center bore which is 1mm more than Subaru. Both typically use high offset wheels. They should fit fine.
    You may not be able to go the other way around though. VW uses 14mm studs and Subaru uses 12mm studs. Subaru may use too narrow stud holes.
  7. idget
  8. 02_Rexxxy
    02_Rexxxy Active Member
    VW uses ball seat and Subaru uses conical seat lug nuts/bolts remember...you'll have to go to a tire hardware shop or online and order the correct seat to properly torque the wheels.
