injector help
Discussion in 'Modifications And Maintenance' started by AWDimprezaL, Mar 15, 2005.
  1. AWDimprezaL
    Monticello.
    when i was at u-pull i got some pink injectors from fuji's ej22T...way too rich at WOT, now i just scored some injectors off of a newer OBS, they are gray, and my current injectors are red...what is the difference...i know in 1997 the 2.2 got 2 more hp..is this related to that?
  2. FuJi K
    St. Paul, MN
    Those pink injectors are still good eh? They just flow too much for your application eh? Keep them handy, you can make some $$ off of them! Assuming that the motor is didn't change a lot, the injector flow rates should be really close.
  3. Zola
    Zola Well-Known Member
    St Louis Park
    Why are you changing your injectors?
  4. morganm
    morganm New Member
    How about get the part # off them and comopare those; not what color the tops are ;)
  5. AWDimprezaL
    Monticello.
    well, it was just an experiment...i did the gray ones today, ran even richer then the turbo ones somehow...so im back to stock, i really had no reason to change them, it was easy enough, so no harm done, now i have some turbo fuel rails, and injectors to make some money off of!:D
