injector placement
Discussion in 'Modifications And Maintenance' started by wrxjoe, May 3, 2007.
  1. wrxjoe
    wrxjoe Well-Known Member
    Hey, I just got modded stockers flow tested, they read 836,836,844,852
    now I just want to know what cyclinders to put them in. I know to put the larger one in the lean cylinder but which one is that? please don't give numbers, I need to know like drivers side front, etc. Thanks
    Joe
  2. wall of tvs
    1 - pass. front
    2 - drivers front
    3 - pass rear
    4 - drivers rear
    852 - 4
    844 - 2
    836s - 3 & 1
    Those are some big freaking injectors for your setup, mang! Sweet.
  3. Scuba Steve
    wow, they are big. in fact, aren't they technically too big? What turbo are you going with?
  4. wrxjoe
    vf39...
  5. Iroc-Z
    Iroc-Z Well-Known Member
    He will just have to add more boost to compensate
  6. w_o_t_boy
    w_o_t_boy Well-Known Member
    LOL..
  7. wall of tvs
    or e85 ;)
    ...or both :slayer:
  8. bikerboy
    I would do them
    852- #3
    844- #4
    836- #1,2
  9. 02blubru
    What difference does it make? Just trying to learn.
  10. WRX1
    Yep, put the richest injectors in the back and scale for the fronts.
  11. 02blubru
    anyone????
  12. WRX1
    Because the rear cylinders run the hottest, and the extra gas from the larger injectors help keep things a little cooler.
  13. 02blubru
    Thanks russ
  14. wrxjoe
    I went with the first suggestion and now I just have to get the turbo back on... (on my way out now)
