Intake manifold ?
Discussion in 'Modifications And Maintenance' started by k_thaosta, Mar 21, 2006.
  1. k_thaosta
    k_thaosta Well-Known Member
    Mexico City
    Will the WRX manifold fit on the FXT/STI heads?
    If not, what will the WRX manifold fit?
  2. bikerboy
    on the water looking for the sandbox
    What throttle body is going to be used?
  3. k_thaosta
    Mexico City
    stock wrx throttle body, but depends on what will work
  4. ILLICITWERX
    ILLICITWERX New Member
    Glyndon
    the wrx intake manifold is the same as the sti manifold...
  5. bikerboy
    Sorry that is not correct. The WRX has an IAC and the STi is DBW. they are set up differently
  6. ILLICITWERX
    Glyndon
    sorry i was missinformed then
  7. ILLICITWERX
    Glyndon
    could you explain what IAC and DWB mean?
  8. bikerboy
    Sorry the WRX ej20 has an Idle Air Controler (IAC) to control the idle. The STi or EJ257 cars are Drive By Wire (DBW)
  9. k_thaosta
    Mexico City
    Sorry but does this means it will work or not work sti/fxt heads?
  10. readymix
    Eloh, El
    it means you need to use the WRX throttle body.
  11. PHATsuby
    PHATsuby Well-Known Member
    are the TGV housings the same bolt pattern for both?
    Ben
